I turned the tv on then got nothing from the remote I've changed batteries got my other samsung remote and it works perfectly on both tvs is there a easy way to reset it
SOURCE: i have a brand new
You may need to recode the remote since you changed batteries, and the newly installed batteries are new, and installed correctly.
SOURCE: remote won't work
Hi I had the same problem last night, so I took the batterys out and left it for a Day, have just put them back and its working for the moment, hope that it keeps on working !!! good luck with yours.
SOURCE: bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
SOURCE: my samsung remote BN59-00852A just stopped
Try the instructions below. If you need to replace the remote, you can order one from:
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=BN59-00852A&uuid=12967730823440
Before replacing the remote, try the following:
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the TV unit.
Let me know if you have further questions. Please make sure to rate this solution. Thanks.
