Display shows nothing and film will not wind. all new Batteries AAA & Lithum
SOURCE: Minolta Maxxum 5000
I had the same problem with a maxxum 7000. Traced it to a bit of corrosion in the battery pack. It let just enough power through to run the computer, but upon releasing the shutter, it shut off.
You might check that. corrosion can be cleaned with vinegar.
-John
SOURCE: wind film?
Behind the LCD screen on the back of the camera, is a a gray button marked "R", and a gray slide switch to the immediate left of that.
Press and hold the R button, while sliding the switch to the left, this can be easily done with one thumb. the display will blink 0 and the motor will stop when rewinding is complete.
-John
SOURCE: need manual for 370 minolta camera and new or used base piece
Check the manual below:
CLICK HERE TO CONTINUE TO
PDF MANUAL
