My sons ipad air was working fine, he was watching cheats for his xbox game and it just switched off, it now will not turn back on and when you put it on charge it does not show anything at all. I have tried holding the on button for a few seconds but still nothing... please help it is for school and we only brought it a few weeks ago
SOURCE: Apple Ipad won't charge
IThe iPad needs more power than the average USB device. It doesn't run and charge at the same time on a regular USB port. If it doesn't charge with the original charger though, you have a hardware issue. You can always take it to the apple store and demonstrate the problem there, you'll probably receive a replacement. If you have issues with the warranty, there are third party places that will find our what's wrong. If you want to do it yourself, the good news is, it's not too hard to open it. Here is an iPad Repair Guide that shows how to open an iPad. If you want somebody else to do it for you go to iPad Repair NYC.
SOURCE: My iPad will not turn
If it refuses to charge when connected to any computer, charger using any charging cord and you have done a hard reset you have a broken logic board or dock connector and should take it to the apple store. If they won't help you, you can try to replace the part yourself, it is available on any auction website. There is an iPad Repair service that can fix it for you, but if you're a little tech savy you should use an iPad repair guide that teaches you how to do the repair yourself.
SOURCE: How do I make the new iPad's battery recharge faster?
There are many things you might be doing wrong but slow battery charge is a problem with the new iPad. The battery is actually a lot bigger than the iPad 2 which means it is going to take you much longer to charge.
Use the provided charger and don't charge from your computer. It is almost twice as slow to do it plugged into a computer. Charge it at night to give it the most time to charge as possible. I usually turn it off so programs don't run and slow down the charging speed. Every little bit helps.
I can help you with other things too if you ask.
SOURCE: iPad shows blank black screen & won't turn off ~ how do I fix?
Try reseting the iPad by holding the home and power buttons simultaneously until the iPad completely shuts down and the Apple logo appears.
Once the Apple logo appears you can release the buttons. If this does not work, you may need to connect your iPad to your computer and do a factory restore using iTunes.
SOURCE: my ipad wont charge , icon shows it's charging but it not ?
To get Ipad to show as charging download Asus AiCharger from web and restart computer after install.Plug in usb from Ipad and should now show charging http://event.asus.com/mb/2010/ai_charger/
