Re: Whats the general code for tecno T780. like if u want...
I have a phone made TACNO T780, IT FELD INSIDE WATER I REMOVE IT AND DRY IT, BUT IF I INSINT SIM IS GIVEN ME
(NO SERVICER) SO PLEASE WHAT IS THE PROBLEM?
It is customary to separate different parts of a phone number with a space but that is for human recognition only. Some phonebooks allow a space so it looks right to us even though it serves no purpose when dialling the number. A lot of phonebooks do not allow a space and force people to type the number as it will be seen by the phone software.
The space when typing names and the delete key vary between the make and type of phone. My phone uses the zero (0) key as a space bar. If a zero is required the key is kept depressed for a second longer. My phone has a dedicated "clear" key but lots of phones use the "back" key for delete.
My advice is to keep playing around and reach for the instruction manual if all else fails.
Go to your phonebook, press the option key and scroll down to mark all, after marking all the names, now press the option key again and press delete, all the enteries on your phonebook will be deleted at once.
Please makesure that they are all mark before you delete them.
Phonebook (Storing Phone Numbers, Names, Distinctive Rings and Speed Dial) You can store names and numbers in your phone’s phonebook, search for names alphabetically, and dial phonebook entries with just a few key presses. You can store up to 100 numbers in the base and up to 100 additional numbers in each registered handset. The phone uses the same memory to store phonebook entries and Caller ID messages. If the shared memory is already full, the phone will not store any more phonebook entries. You will have to delete some of the Caller ID messages before you can store a new phonebook entry. 1) When the phone is in standby mode, press phonebook. 2) Press the STORE soft key, S t o r e / E d i t N a m e appears. 3) Enter the name (up to 16 characters) by using the number keypad (see the "Steps for Entering Names and Special Characters" on page 44). If a name is not required, go to step 4. <No Name> will be used as the name. 4) Press the OK soft key to store the name; S t o r e / E d i t N o . appears. 5) Use the number keypad, */tone/<, or #/> to enter the phone number (up to 20 digits). If you make an error, use the DELETE soft key to erase the incorrect digits. When you are finished, press the OK soft key to store the number.
6) If you store the phonebook entry from the handset, D i s t i n c t i v e R i n g appears. Press volume up/down to move the pointer to one of the Distinctive Ring options and then press the OK soft key. 7) S p e e d D i a l appears. Press volume up/down to move the pointer to select the Speed Dial location (10 locations: SPD1-SPD0). 8) Press the OK soft key. You will hear a confirmation tone, and D o n e ! appears in the display. EASY DOES IT! :)
You must have copied each number with two names or there may be double entery inside phone.
possibly problems
Double entry for single number
same contact in phone and sim
missing country code (ex. +91 xxx) in special cases
Solution:
take one other phone, and delete that number from your phone (sim n phone both memory) after deleting that contact details, misscall from working phone to your phone, and store that contact in ur phonebook
delete all contacts and add one time only. make sure no double copying
I had the same problem but figured it out. For some dumb reason, Caller ID numbers count against your total phonebook memory. So if you just delete all your Caller ID numbers (press the "Caller ID" button and then the "delete" button) then you'll be able to store new numbers in your phonebook.
If I could get my hands on the Uniden engineer that is responsible for this, I'd smack him! :)
most of the SE phone have two types of contact saving
1- in phone memory
2- in SIM card memory
if u have contacts saved in SIM memory but u r using
phonebook memory then it is default
if u save any contact in phone memory u have an option too
to copy it to SIM memory
for deleting a contact it will behave like this:
for example, u have a contact saved in phone memory
as well as in SIM memory
if u delete this contact, then it will be deleted from phone
memory but not from SIM memory
and when u are called from same number
(which is not present in Phone memory but is in SIM)
it displays the name again
