20 Most Recent
Nokia 7310 Cellular Phone Questions & Answers
Reset the security code of nokia7310
Hi Friend,
By typing this
*#7328748263373738# you can reset the security code and assign new code
Check and revert back
Thank for using Fixya
Regards,
Ayyasam
Is is fixable problem 789
Hi,what makes number 789 keys not working is because there is an IC on the phone board that controls those keys. The IC is bad and will need replacement for those keys to work.
When you replace the IC those keys will function again.
Have a nice day.
How to repair nokia 7310c contact service problem
There might be a hardware problem but as well it could be just software related. Try reinstalling the device firmware.
***Prerequsite:
Install Nokia PC Suite for your phone and the drivers if you haven't already done that!
First of all, you'll need a program and the necessary firmware files:
1. Phoenix Service Suite (2012 or any other version. Search for it on Google)
2. Nokia 7310c firmware (
RM 379 DP20 3 00 sw 09 40 7310c)
Install Phoenix Service Suite, extract the software (it will auto-extract the necessary files in the right folder, but first it is necessary to install Phoenix).
Now, after staring Phoenix, do the following:
1. Click File > Open product (not Open profile!)
2. Select RM-379 from the list (you can type that in the "Type filter" text box to find it faster)
3. Select the product code (RM-379) from the list and press OK
4. Now press Flashing (at the top menu, where is also File)
5. Check Dead phone USB flashing on the new dialog box that appears.
6. Click the browse button at the Product code input (top section of the new dialog box)
7. Select an option. Any will do. The difference is between regions and languages. But since I don't know from where are you or what language you'll need on your phone, I can't tell you exactly what to choose. But all region files have "English" avaible
8. Press Refurbish. Take out the phone battery, insert the USB cable, then insert the battery. If any dialog pops up, press OK.
8* At this point, DO NOT DISCONNECT THE USB CABLE until the process is finished!
This process should take about 5-10 minutes and after it is finished, the phone should boot up by itself and everything will be fine.
How want reset security lock
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000 or 1122 9999
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
Unlocking problem
The easiest way to unlock your Android smartphone now is to completely reset it. Doing so will erase all your settings and files that are not stored on the memory card.
Depending on the model and maker of your smartphone (Samsung, HTC, LG etc.) the procedure might be slightly different but the idea is to enter tAndroid Recovery Mode and wipe all data + cache.
For example, to enter Recovery Mode on Samsung Galaxy S2 you need to:
1. Turn off the phone
2. Press Volume Up + Power button until it starts (here is the key difference. The keys needed to be pressed are different. Search on google for [SMARTPHONE_NAME] recovery menu ex: HTC Desire HD recovery menu, Samsung Galaxy S3 recovery menu, etc)
3. The Recovery Mode should show up in some seconds
4. Using the volume keys, select Wipe Data / Factory Reset and press menu or power to select.
5. Select "yes" using the same navigation as from step 4.
6. After resetting, it will return to main recovery screen. Do the same for cache partition
7. After cache partition reset is done, select Reboot
8. Phone reboots and now you'll have to set everything up again, but at least the password is removed.
Charger not support
your phones battier is not working well you must go to a store and get a new one
Reset code
what phone do you have I think I can help you?
Master code
"There are two method of doing hard format on most of the nokia devices.1.manually1. go to menu and search for setting option.2.enter in setting menu and search for restore factory setting option.3. when you press on restore factory setting it will ask you for code enter 12345 the default code.now you are done.2.USING CODE.DIAL *#7370# on main screen.a menu will pop up like restoring all data press ok enter 12345 default code.you are done now.TO RESTORE SETTINGS ONLY.USE THE CODE *#7780# "
I forgot my security code for nokia 7310c can you
Default 6 Digit Security code: 000999 or 1122
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Forgot security code
First install all the necessary drivers for your phone.Then you'll need Nemesis Service Suite to read the flash memory (find it at Phone Info -> Permanent Memory tab ->Read in Nemesis Service Suite a.k.a NSS, not on the phone). After the entire permanent memory is dumped, you should find a file in C:\Program Files\NSS\Backup\pm or C:\Program Files (x86)\NSS\Backup\pm. The file name should be your imei.pm For example(358123123123123.pm). Open it with a good text editor (Notepad++ recommended), search for a line (CTRL+F) that contains the following string: [308]Then there should be another two lines beneath it that look like this:0=00 or other numbers1=31323334350000000 <--this is the line you needIn this example, the security code should be 12345 because you take only the even positions until you have 5 digits then you ignore the rest of the line.3 1 3 2 3 3 3 4 3 5 0 0 0 0
I forgot my nokia 7310c security code how can i
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
