probably either: too big for the camera or the HC is not compatible. Did you try to format the card? Put the other one back in and see if that one still works. If so, take the card back, with thte camera and show the vendor that it does not work. Get a Non-HC card. It will probably be smaller as well, because the bigger capacity is a relative design increase with the speed (HC).
Brock
I have a kodak z710 camera with a 2 gig card in it. I was wanting to get a 4 gig sdhc and i wasn't sure if the HC would work with this camera. HC stands for high capacity which means it allows the camera to load files on to the card faster. this may be the problem the kodak may not be HC compatable. but as i have said i have a 2 gig and it works fine with that. and i have a friend that has a 4 gig in thiers but once again i don't think it is HC so i would exchange the card if you can for just a regular SD/MMC card or SD card
THe HC chip set for SD's and micro SD's have different programming in them and are unfortunately not backwards compatable with a standard SD host port. For you laptop, I reccoment getting a USB SD chip adapter. They're only like $6-$10 depending upon the brand. For your phone, however, I reccomend you take it back to the store for a trade-in on a standard SD chip, or for a complete refund so you can buy one from a store that carries standards.
I think that because it is SD HC, You wont be able to use it. This is caused because your camera is old, and the card reader on your camera is not SD HC.
