20 Most Recent
Vivitar VIVICAM 7388 Digital Camera Questions & Answers
Driver missing for ViviCam 7388s
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Loading music
The 7388 is a camera not a music player. You can put music on a memory card, but the camera will not play it back.
I cant get my pictures
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
I have Vivitar vivicam
HiYour camera will hard to repair due to lack of part supply. However, depend on your camera lens condition some tech could save your camera. You might bring it to your local repair shop.Or, I can tell you your unit repairable or not if you post to the damaged picture here.
Cannot set the date on Vivitar Vivicam F328.
Press the HOME button to bring up the main menu. Touch the pliers-and-screwdriver icon function area to enter the Setup menu. Touch the down-arrow function area repeatedly until "Date" appears. Touch the calendar function area to enter the Date menu.
Vivitar digital camera
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Vivitar vivicam 7388s lens won't go back into
Hi Dear,
This issue is not with the battery. This is due to the misalignment of the camera lens. This is a delicate hardware problem. Hence,i would suggest you to take it to some professional or your authorized service center and get it repaired there only. Trying to repair it on your own might make the situation worse and would cost a lot money.
If you need more information on this. Please do write to use.
Have a nice day.
Where is the battery compartment
its so simple,just slide through your manual..
or defintly it will be in the LOWER part of the camera with[ (=>)to open ] symbol look closely
rate me!!!
