Danby DPAC12031 Air Conditioner Logo
Posted on Jun 06, 2009
Spare sliding window kit for portable ac
I am looking to purchase a spare sliding window kit for my DPAC 13009 Danby portable air conditioner. I have two patio doors ( no windows ) in my apartment and I would like to have the kit set up at all times on both patio doors.
5 Related Answers
Anonymous
  • Posted on May 19, 2009
SOURCE: Actually it's a DPAC 13009. We need to extend the 2 air pipes 4 to 5 feet each to reach upper windows over patio doors to keep doors locked and secure. Does Danby provide air pipe extensions? Thanks.
No solution possible, given that the air ducts going up over the patio doors are quite an eyesore. This building is entirely fieldstone outside, so either the patio doors or windows above them are the only way to go in or out.
We will return the unit and get instead one that can be placed in the upper window and activated by remote control. Thanks.
Anonymous
  • Posted on May 28, 2009
SOURCE: DPAC 13009 portable air conditioning problem
Remove your remote control on the unit, follow the manual step by step. First, do the emergency on/off button, then operate the air conditioning using the remote control, follow the procedure of your manual.You may notice a clicking sound of your remote control. The yellow/green color of your emegency on/off button will turn to blue. Do not put it back your remote control on the unit because he may sense the temperature of the vent, and your air conditioning will not stay on, it will shut off every five minutes. Your problem is solve.
Regards,
Cesar
1STHVACMAN
  • 69 Answers
  • Posted on Aug 03, 2009
SOURCE: Using the DPAC 8020 AIR Conditioner (Danby)
these portable units will usually have a knob reading from low to high. set it about half way and adjust as needed. half way is usually low 70's
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Jun 26, 2011
SOURCE: How do you install Danby
This whirlpool manual will give an idea: 10000 btu portable
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Anonymous
  • 20 Answers
  • Posted on Jul 03, 2011
SOURCE: we bought the danby Premiere
check service tag on unit what is the amp rating on the unit does it exceed your breaker size??
I have a DPAC 13009 that was purchased a year ago at COSTCO. It has worked fine until now. It began making weird noises and then kept shutting off. Upon further examination there were pieces of white...
From your description, I would have to agree with you on the pieces being from a broken fan. The good news is, that your model has a 24 month in home service warranty, so the parts and labor to repair are covered. But, the real key is having a Proof of Purchase. Armed with that, you're good to go.
Contact Danby Consumer Support 1-800-263-2629, to file a Warranty Claim.
I hope this helped you and thanks for choosing FixYa.
We bought the danby Premiere DPAC 13009 for our trailer and it is blowing the breaker.
1helpful
Need a copy of the manual
Here's a link to the Owner's Manual for your Model Danby Portable Air Conditioner.
Your model has been discontinued, so download and print this manual for future reference. Making sure to keep it in a save, accessible place.
http://www.danby.ca/cms/uploads/products/en_manual/DPAC%20%209030%20and%2012030%20manual.pdf
Hope this helped you. Please let me know. Thanks.
I have a Danby Mod.# DPAC 10061 portable A\C, the
This sounds like it could be a power supply problem. It may be very simple. I think I would first just unplug the unit, open it up, look for the PS connectors, and check/wiggle them to make sure there is good contact.
I went to the Danby's website:
https://www.danby.com/
And I was unable to find any service or owner's manuals in PDF format. The site does however have a locator for service shops. Good Luck!
da Marty
8helpful
Regards,
Cesar
Top Danby Heating & Cooling Experts
ZJ Limited
ZJ Limited
john h
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
