Have a cam got error c31 22,c31 23 when i play a cassete 10 seconds i get this error and it says reinsert a cassete also when i play a cassete image cannot been seen i get blue screen
SOURCE: error message 31:22 reinsert cassette tape
reel sensor is the problem of your camera it is a common problem to that model,maybe the pinch roller is loosen to the post cause of the lock of that is been broke..that roller is that one that pulling the tape...only a technician can put it back to the mechanism and replace that lock...in sony service they replace the whole assembly and cost a lots...i suggest find other service center for fixing it...hope that roller is not lost in your camera...
SOURCE: Smacking camera does not work- HDV ZR1U SONY
Look at my most recent post about this, or better yet, go to camerahacker.com to see many possible solutions plus diagrams and actual pictures. You'll have to scroll down about 60 pages or so, ther are over 2,000 complaints about this error code alone on just this one website!
YOu may be missing the roller, the white plastic lock or both. Turn the camera upside down, remove the tape and gently shake it and see if anything comes out.
Re-install per the directions on that website. If not sure what to do and you find the parts, post here again and I'll try to help you. good luck! BOYCOTT SONY!!!!!
SOURCE: REINSERT THE CASSEETE
Me also getting the same problem.. but some times it is getting okk... what i m doing is, put the casset while pushing the cassete hold little bit down.. i think it is due to the improper position of the cassete holder...
SOURCE: My sony handycam digital 8 285E is showing problem C : 31: 22
Well I have not had this happen in my own Sony 340 8 camera, but I have head of it lots of times.
Make sure your tape is re-wound to start, check that the safe tab on rear of take is not pulled over the hole (it prevents writing over stuff you want to keep.
