Sony Handycam Video Cameras • Uploaded on Aug 13, 2013
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
This is usually caused by a defective LCD module or a defective flex cable that connects the LCD to the camera. I recommend replacing them both at the same time. The LCD / Touchscreen module is no longer available from Sony at an reasonable price for this Model. However, I have a limited supply of them in stock as well as an aftermarket supplier with hundreds of them.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have it repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
This is usually caused by a defective LCD module or a defective flex cable that connects the LCD to the camera. I recommend replacing them both at the same time. The LCD / Touchscreen module is no longer available from Sony at an economic price for this Model. However, I have a limited supply of them in stock as well as an aftermarket supplier with hundreds of them.
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
92 questions posted
310 Questions
243 Questions
242 Questions
159 Questions
150 Questions
