Komono Magnus Watch Logo
A
Anonymous Posted on Feb 04, 2014
Turn off alarm - Komono Magnus Watch
Swiss Army Whisper Alarm Clock - Problem turning off the Alarm
You need to actually turn the alarm OFF or it repeats every day. The push button does just that, it turns it off when it wakes you up, but it is still set for the next day.
I was trying to find a manual, but there doesn't appear to be one online, so contact Victorinox direct.
https://www.victorinox.com/ca/en/Swiss-Army-Knives/Service/Contact/cms/contact
https://www.google.com/search?q=Swiss+Army+Whisper+Alarm+Clock+manual
How do I unhide alarms 2 and 3?
Set multiple alarms. If any alarm is active,(picture of alarm hear) appears in time display A. Press MODE repeatedly until ALARM appears, followed by ALM1. Press STOP/RESET to select Alarm to set. B. Press SET/RECALL to set alarm. HOURS digits will flash. Press +/- to change HOURS. C. Press NEXT and +/- to set MINUTES, AM or PM (if primary time display is in 12-hour format), DAILY, WKDAYS, WKENDS, or day of the week (weekly alarm). D. Press DONE to exit. E. Press +/- to set different Alarm. Set as above. F. In Alarm mode, press START/SPLIT to turn Alarm ON or OFF. TIP: Alarms apply to selected Time Zone of watch display. Backup Alarm sounds after 5 minutes if no button is pressed. Turning off any Alarm or backup will not affect other alarms. http://assets.timex.com/user_guides/W191_M131/W191_M131_NA_EN.pdf
How do you turn off the alarm on a timex marathon wr50m watch?
1. Press Mode- and set it on the alarm.
2. When you are here, press the start/stop button and the little alarm signal will change. If it is dark, the alarm is on. If you keep pressing the stop/start button the darkness will go away, meaning the alarm is now off.
Can not turn off alarm
If you have Alarms on, you will see a small bar above the Alarm numbers (1 to 5).
Press the Mode button to get to Alarm mode. You will see Bell AL on the top. Use Reverse/Forward to switch to the Alarm you want to turn off. The Alarm number will increase/decrease on the right of the time.
Use the 12/24Hr button to cycle through the Alarm options.
When the Alarm bar is blank, the alarm s/b off.
Note: The Casio manuals are online.
http://www.manualslib.com/manual/221397/Casio-Db36-1av.html
25helpful
Turn off alarm for sportline 220/221 stop watch
Press the mode button twice to enter the alarm setting mode, the press the other two button simultaneously to turn OFF the alarm.
The same actions will turn the alarm ON.
Jan 27, 2010 • Watches
3helpful
I can't turn off the alarm. Please help
to turn the alarm off press the mode button until alarm 1, 2, or 3, appears (as required).
Press the start/split button to turn off the alarm.
57helpful
2answers
Can't turn off alarm
Here are the instructions to view, change alarm time and turn off alarm:
From normal time display:
Press MODE once to display stop watch.
Press MODE again to change alarm time.
Press MODE again to change time.
Press RESET once to display current alarm time.
Press and hold RESET then press START to turn on and off alarm (watch for alarm symbol on top left)
Press and hold RESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
Hope this helps.
May 05, 2009 • Watches
1helpful
Turning alarm offI
how do I turn off the hourly setting
3helpful
press mode four times until you get to the alarm screen (on mine it is four), then press start/stop to cycle through turn the alarm on, chime on, alarm off, chime off
Dec 26, 2008 • Watches
8helpful
5answers
Unwanted alarm
using the button at bottom left of watch, set to the alarm mode and press the button at bottom right to toggle between alarm settings. The bell and wave symbols will appear and disappear on top left of watch display.
Top Komono Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Komono Watch Expert? Answer questions, earn points and help others
