20 Most Recent Casio DB36-1AV Wrist Watch Questions & Answers
Open the back (4 screws). Careful with the rubber seal and spring inside. Use a pin to pry the battery clip away from the bottom of the battery. You need to pry the bottom out and up. When the clip releases, the battery is easy to remove/replace.
Casio DB36-1AV... | Answered on Aug 22, 2014
If you have Alarms on, you will see a small bar above the Alarm numbers (1 to 5).
Press the Mode button to get to Alarm mode. You will see Bell AL on the top. Use Reverse/Forward to switch to the Alarm you want to turn off. The Alarm number will increase/decrease on the right of the time.
Use the 12/24Hr button to cycle through the Alarm options.
When the Alarm bar is blank, the alarm s/b off.
Note: The Casio manuals are online.
http://www.manualslib.com/manual/221397/Casio-Db36-1av.html
Change battery
There is a clip over the battery and then down on one side. You need something tiny and sharp... like a needle. You can insert the needle into the clip between the battery and the outside edge of the clip and gently pry the clip out and away from the battery.
Set the right date and year and day will come automatically.
Casio DB36-1AV... | Answered on Jan 28, 2014
First possibility is that your battery is dead....
Casio DB36-1AV... | Answered on Dec 03, 2013
find it here:
http://world.casio.com/wat/download/en/manual/
Rate me, please.
Casio DB36-1AV... | Answered on May 27, 2013
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Casio DB36-1AV... | Answered on Jul 18, 2010
http://www.youtube.com/watch?v=ogCz2vjUKVg
Casio DB36-1AV... | Answered on Jan 19, 2010
go to alarm mode and choose the alarm (1-5) using the "forward" and "reverse" buttons, then hold the bottom right button down to toggle it on or off
Casio DB36-1AV... | Answered on Jan 15, 2010
Try to find solution here:
http://www.timex.com/gp/node/n/255235011/190-2521384-6105829?ie=UTF8&timexBrand=core
Rate me, please.
Casio DB36-1AV... | Answered on Jul 23, 2009
To Toggle between 12-hour and 24-hour timekeeping:
In the Timekeeping Mode (regular watch display), press the lower right-hand button to toggle between 12 and 24 hour timekeeping.
Casio Watches | Answered Yesterday
Please Google (casio)(EFA 124)(manual) without parens.
Casio Watches | Answered on May 31, 2019
you posted to USA web site that is only English, not obvious that?
Casio Watches | Answered on May 24, 2019
Hi Jamie, the best thing to do is take it to a qualified Jewler/watch repairer.
Casio Watches | Answered on May 19, 2019
Casio DB36-1AV Wrist Watch Logo
12 questions posted
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Casio Watches
  • Casio Watches
Most Popular Question
turn off alarm
  • Watches
