Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
A
Anonymous Posted on Feb 02, 2014
Will not hold temperature - Jenn-Air SCE30600 Slide-In Electric Kitchen Range
1helpful
How do I change my 2008 Cadillac back to celsius
Push and hold the Ambient (outside) Temperature button down while pressing the Temperature Down button. After several seconds the display will toggle.
My Emerson thermostat reset the temperature from 18C to 21C on it's own. It was in temperature hold mode when it did this.
maybe you had a temporary hold rather than permanent hold. turn the temp back with permanent hold.
How do I set Honeywell thermostat RTH300/RTH221 to one set, fixed temperature? Manual is a bit unclear
hold is for a fixed temp. run resumes a program. if hold is displayed on right side you are not running a program. the temp will change back to room temp NOT set point temp, this is normal but your setpoint temp did not change if hold is displayed.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
How do set temperature target. Its set at 68 now and cannot change it. We just moved in and have no instructions
To set the temperature and by pass the program feature press "HOLD" This feature is alternate action each time you press it changes from on or off, off to on.
This will make your 3M-22 act like a non-progammable thermostat. It will hold the target temperature you set indefinitely, until you turn HOLD off. Take care using the HOLD function as the program is now bypassed. To set a hold target temperature, press HOLD and use the +/- buttons to select your hold temperature. The HOLD icon will display on the HOME screen indicating you have changed the Target Temperature. The system will HOLD this temperature until you return to the manual screen. To turn off hold press HOLD again. HOLD is also canceled when you set the mode to OFF.
http://www.radiothermostat.com/filtrete/guides/3M-22-Operation-10may10.pdf
These things are like the old VHS tapes to program.
Hope this has helped?
1helpful
Outside temperature sensor
The outside air temperature indicator's displayed temperature can be recalibrated. Press and hold the reset select button for 10 seconds . While you continue to hold the button, the display will scroll through temperature settings from +3 to -3. When the desired correction value appears on the display, release the button, and the recalibrated outside air temperature will be displayed. Each time a desired correction value is entered, it replaces the previous value. Give that a try mmkayyy:)
I reset my hunter thermostate and now its showing Celcius instade of Ferienheit temperatures, how can I change it back?
Press and hold for about 1 second to enter Manual Override mode. When display flashes, you can release the key. ■ Press again to change to your desired Set Temperature. Hold the key for 2 seconds to fast-advance the Set Temperature. ■ Press to return to normal mode, or wait 5 seconds for it to return automatically. ■ The current program number will flash to signify the Temporary Override. ■ At the next program change time, the Temporary Override is cancelled, and the next program temperature becomes the setpoint temperature. To end the Temporary Manual Override: ■ Press and wait for HOLD to display on the LCD. ■ Press again. This will return the set temperature to the current program set temperature.
2answers
I'm having a problem with my thermostat. It's a
Set Current Time and Day
1. Press TIME button once. The display will show the hour only.
EXAMPLE: PM
2. Press and hold either or until you reach the correct
hour and AM/PM designation (AM begins at midnight; PM
begins at noon).
3. Press TIME once. The display window will show the minutes
only. 1F80-361 pdf
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2helpful
My freezer will not hold temperature. Only a year
If what you say is accurate, I would look at either a weak compressor or and issue with the expansion device. (Cap tube, TXV)
What are your pressures and what freon are you using? Does the door(s) seal tight?
Top Jenn-Air Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
