I have been using wii fit for a few months now but all of a sudden the blue light keeps flickering and it says it has lost communication. I can switch it off and on again but about 3 minutes later it does the same thing-it is soooo frustrating! I have changed the batteries but it doesn't seem to have helped. I cant find the Wii fit book to find out what i can do about it.
SOURCE: WII FIT BALANCE BOARD BLUE LIGHT WONT STAY ON
new batteries..... lol and then sync it again..
SOURCE: Remote keeps losing communication
Well, when you dont use it for a certain amount of time then it auto shuts down to save the battery.
Say you played for 10min and then went to go do something, it goes into hibernation mode until a button is pressed.
SOURCE: wii remote keeps losing communication with the main unit
It sounds like your sensor bar is going out. I have heard from numerous people that they go bad and start acting very sporadic( somedays they work and somedays they don't) Also check to make sure your bar is sitting level on your T.V. and not pointing up or down. If it is the slightest bit off then the bar can't "see" the remotes all the time.
SOURCE: wii fit platform does not stay switched on after
have this message came out "an error has occurred. press the eject button and remove the disc, then turn the wii console off and refer tothe wii operations manual for help troubleshooting." i tried several times, but same message pop out. izzit something do to with NTSC?
