The crib is probably 10-15 yrs. old the mattress spring has four moveable flat arms on each corner that slide (not hook) into the slots on the crib frame but I can't figure out how they are suppose to stay in the slots. There is a hole at the end of the flat arm. There were no extra screws left after I put the crib together. This is a used crib bought on craig list.
The above picture is how our Jardine Enterprises crib attaches the mattress support to the frame. I am thinking you need the bolts to make your crib work. And that might be a chore unless you are very handy with hardware. Also, being a new parent ourselves, I would recommend against anything but the safest crib for your child. Call the original owner--see if they can find the bolts/hardware, if not get a complete unit if you can afford it, it may cost more in the short run, but may save a serious injury or worse. Also, if you go the used route see if it has been recalled, you can start here:
http://www.thenewparentsguide.com/choosing-a-baby-crib.htm
could you resend picture would load. Thanks
