20 Most Recent Evenflo Embrace Questions & Answers
Yes, you can out a newborn in a car seat without a base. The base does not affect the safety of the car seat. It is only a matter of convenience for you in getting the car seat in and out of the car. So it is not a problem.
Evenflo Embrace | Answered on Apr 08, 2013
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Evenflo Embrace | Answered on Dec 17, 2012
use a tiny flat-head screw driver to pull outwards on the tab (this is a blue plastic tab on mine) that holds the white plastic u-shaped (canopy part) in. I didnt think it would be this difficult but it is... the graco ones are much easier to take off to wash.
Evenflo Embrace | Answered on Jan 16, 2011
you need to turn the car seat over and on the very bottom there are two gold rectangle-shaped clips holding the straps. You can pop these out and feed them through the hole....not like other car seats where the straps unattach up at the shoulder end.
Evenflo Embrace | Answered on Nov 27, 2010
Squeeze the side grips and pull forward.
Evenflo Embrace | Answered on Sep 15, 2010
Hi. Go to this link http://www.evenflo.com/category.aspx?id=7
Select your seat, click on manuals and you will have it as a free download. J.
Evenflo Embrace | Answered on Aug 24, 2010
mcdevito75 here, You may be able to get the instructions online at Evenflo.com try.
Evenflo Embrace | Answered on Jun 24, 2010
There's no way to fix it and Evenflo will not refund it if you're outside of warranty. We had the same problem. I think they need to be held accountable for a faulty product and stand behind it.
Evenflo Embrace | Answered on Apr 09, 2010
Evenflo has a GREAT website section on using and installing their carseats. The manufacturer is the final authority on keeping your child safe in their seat: don't accept advice from anyone else!
http://www.evenflo.com/sme_carseats.aspx?id=321
You also ought to have your instruction manual for reference: order it for free, at this link:
https://plweb.evenflo.com/replacement_parts.aspx
Evenflo Embrace | Answered on Mar 25, 2010
no it cant prove to arrange with a piece of wood
Evenflo Embrace | Answered on Nov 15, 2009
see if it is passed right under in the pocket you have in the back
put it in the bath and wash it with a brush by hand
You're trying to unattach the straps from the wrong end....flip the car seat over and on the very bottom there is a little gold clip that pops out and you can push through the hole.
Evenflo Embrace | Answered on Nov 11, 2009
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Evenflo Embrace | Answered on Sep 22, 2009
The straps are usaully threaded through the back and a large buckle holds them in place, if this is the type you have you just thread the buckle through to the front and then lift starps and thread through to the higher hole. failing this take it back to where you bought it and ask, or if you bought it off the internet take it into your nearest baby item seller and they will be able to show you.
Evenflo Embrace | Answered on Jul 07, 2009
Evenflo Embrace Logo
Popular Tags
57 questions posted
Top Evenflo Baby Gear Experts
Ekse
Colin Stickland
Colin Stickland
Matthew Boulden
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
View Most Popular
Evenflo Baby Gear
  • Evenflo Baby Gear
Most Popular Question
use carseat without base newborn
  • Baby Gear
