Connected vga cable from laptop to TV how do I get audio there is no 3.5 stereo in jack
SOURCE: Connect HP Pavilion dv2000 laptop to Panasonic Viera 42'' plasma
If you get your wallpaper to show on your TV, then you should be almost there.
SOURCE: no picture connecting laptop to LCD TV both Toshiba
Try the fn key and the monitor key (f4?)at the same time to activate external monitor
SOURCE: VGA and Audio cables connected to PC but no audio through TV
if your tv has vga input there should be a "line in" input very near it. VGA can only get its audio source through a "line in" connecting to the coaxial audio inputs will apply the music stream to a different video input on your tv. your tv has video 1, video 2, vga, and so on, but the vga cannot show video and then audio from the video/audio coaxial inputs. you will need something like a dual male tipped 3.5mm audio connector.
Good luck and pls rate this post
SOURCE: how can i connect my toshiba laptop to toshiba tv with vga to rca
Go to Toshiba site or send email to UK office help.
Requesting the info.
Or type in toshiba to google and surk for the info, it is there.
SOURCE: connecting laptop to hd tv
IMake sure that you have the laptop for an VGA OUTPUT. When you toggle between the function keys. When your laptop LCD goes out it is in VGA OUT mode....when you toggle again it should be in LCD/VGA OUT (both TV and laptop should display). You need to set the TV to VGA mode as well...otherwise you might not get an output. If you still have a problem then test on a regular monitor to see if you are getting an output to the monitor
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
