I have a #1+ Husqvarna 1250 Embroidery Machine. The bobbins that came with it have a small indentation in them and work fine. Other Viking bobbins without the indent can not be inserted. What is the correct bobbin and where can I get them. The Local Husqvarna representative has not been able to help.
Give these nice people in TN a try -
Choose Your Brand
SOURCE: Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
SOURCE: bobbin thread won't feed husqvarna viking sewing
sounds like hook to needle timing has shifted. Take to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you.
SOURCE: husqvarna sewing machine - viking 400
SOURCE: viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
SOURCE: the bobbin thread is bird nesting on my viking
Make sure the bobbin is extended out of the bobbin case via the tension spring mechanism in the bobbin case. This provides tension for the bobbin unit. Check to make sure the upper thread has not "jumped out" of the take-up lever so that when the needle first touches the fabric the thread is still taunt and when the needle enters the fabric a small loop is formed right above the fabric and the eye of the needle. If these tips do not help suggest that you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
