20 Most Recent Husqvarna Rose Questions & Answers
12answers
Loaded 3D Embroidery software on
1st try another usb port
2nd uninstall the software and plug the device in only after you have reinstalled the software and you are asked to plug it in. If it doesn't ask then install the software first and try again.
You can also right click on my computer and select manage.
then on the left side of the window select device manager, unplug and plug back the usb dongle and see if any devices appear or disappear also note any yellow ! marks. you may have to press the scan for new hardware button or right click on the window to scan for hardware changes.
11/22/2020 11:27:23 PM • Husqvarna Rose • Answered on Nov 22, 2020
5answers
My Viking Rose sewing machine starts and stops and
The Rose has a sensor on the presser bar assembly that is giving you the grief. The machine thinkss the presser foot is in the raised position.There is a small metal flat spring that has gone bad and causing the error. Find an autorized service center to repair the problem.
11/17/2019 1:17:44 PM • Husqvarna Rose • Answered on Nov 17, 2019
I have a rose embroidery machine which I haven't used for a while and when I try to embroidery, it will only go as far as the 3rd design and only stitch the first color. What can I do
Hello The machine is indicating that it "wants" you to move the hoop into position P2 or P3 according to what is blinking. This is normal. Once that colour is completed stitching, the machine will communicate again for the nest Position. Happy Stitching Sewingirl/
3/20/2017 1:02:10 AM • Husqvarna Rose • Answered on Mar 20, 2017
2answers
Will a Husqvarna #1 Plus embroidery unit work on a Husqvarna Rose machine?
I am sorry to inform you that Husqvarna # 1 embroidery unit does not fit onto the Rose machine. The terminals on the Rose is upright, while on the H # 1 it is flat. If you want to do embroidery on the Rose, you will have to purchase the embroidery unit.
Sad but true
3/16/2017 7:07:10 AM • Husqvarna Rose • Answered on Mar 16, 2017
2answers
Feed dog won't come back up after embroidery is
You must slide the feed dog up/down switch over (consult your manual).
If you slide the switch over, the feed dogs will not come up. It is only when the machine makes a full rotation that the mechanism engages and the feed dogs return to the sewing position.
If the feed dogs will still not raise, then you will need to take it to your dealer.
2/4/2017 5:39:06 PM • Husqvarna Rose • Answered on Feb 04, 2017
manual
Rose Manual
Husqvarna RoseUploaded on Jul 28, 2016
Feed dog wont come up high enough to sew
try this and see if it will work for youWhen you set the switch for the feed dogs in the up position turn the handwheel 1 complete revolution and see if they come up
7/8/2016 3:10:19 PM • Husqvarna Rose • Answered on Jul 08, 2016
My stitch regulator will not work. I have had it looked at 2x but still will not change from 2.5 higher or lower.
What Viking is it ? Have you cleaned between the feeders? If all is clean, try this test. Remove needle. Turn hand wheel so that feeders are up. Put fabric in machine. Lower presser foot. Make sure presser foot pressure is set at normal. Try pulling the fabric towards the front of the machine. It should be hard to pull. If it is easy to pull you need new feeders. They are worn down.
5/3/2015 12:32:25 AM • Husqvarna Rose • Answered on May 03, 2015
2answers
What do I do my husqvarna rose beeps when start to sew in the display window the presser foot flashes what's wrong?
It thinks the presser foot is in the up position. Will need to be repaired by experienced service tech (preferably a certified Viking service tech). There is a clamp that may just be out of place or it could be more involved. Good luck.
4/3/2015 9:01:17 PM • Husqvarna Rose • Answered on Apr 03, 2015
Why is it making a strange noise when I sew?
you probably need to have an authorized Viking repair person check your machine.
2/9/2015 1:43:39 AM • Husqvarna Rose • Answered on Feb 09, 2015
I just rewound my bobbin and it will not come off the holder, what do I do?
When the bobbin is wound with too much tension it crushes the inside and won't come off the spindle. You need to pull all the thread off the bobbin and replace it. Make sure you wind the bobbin at slow speed and the presser foot is up if you wind through the needle.
10/30/2014 8:40:28 AM • Husqvarna Rose • Answered on Oct 30, 2014
What does the flashing circled E on the info
The flashing E means the design is either too big for the sewing field limit (about 3.93 x 3.93") or not centered. From the sound of your description, most likely the design is not centered. Check the design size in software and center it before transferring to the card.
9/10/2014 3:20:10 PM • Husqvarna Rose • Answered on Sep 10, 2014
The bobbin is stuck on the winder
Take a small screw driver and slide it under the bobbin and apply a little pressure and it should pop off.
7/13/2014 6:35:54 PM • Husqvarna Rose • Answered on Jul 13, 2014
Can i buy rose embroidery cards
You might try eBay.
7/13/2014 6:28:13 PM • Husqvarna Rose • Answered on Jul 13, 2014
Sewing machines
Try this link for free manual for the Viking Rose machine - http://new.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Rose_605_manual_EN.pdf There are 2 models called 'Rose'. The original Rose is the manual above. The newer Rose is called the Eden Rose. You can find most user manuals for Viking machines on their website. Here's how: website: http://www.husqvarnaviking.com/us Go to bottom of page on righthand side and click on 'Machine Updates'. If your machine is not listed click on 'All Machines" Scroll down until you find your machine and click on the name of your machine. The link should take you to a page with a picture of your machine and a link to Download the manual which is a PDF file. Good luck.
7/13/2014 6:27:25 PM • Husqvarna Rose • Answered on Jul 13, 2014
How do I change the bulb in my rose?
Your user manual should explain how in detail with pictures. It is sometimes hard to get the bulb out without breaking it. But try this - With machine unplugged/power off lay machine on it's back. Locate the light bulb. You probably have a little rubber device in your accessory case that has a suction cup on each end. One end will say In and the other will say Out. Use the suction cup to grab the bulb and pull straight out. Use the other end to install the new bulb in the machine. If you need a manual - Try this link for free manual for the Viking Rose machine - http://new.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Rose_605_manual_EN.pdf There are 2 models called 'Rose'. The original Rose is the manual above. The newer Rose is called the Eden Rose. You can find most user manuals for Viking machines on their website. Here's how: website: http://www.husqvarnaviking.com/us Go to bottom of page on righthand side and click on 'Machine Updates'. If your machine is not listed click on 'All Machines" Scroll down until you find your machine and click on the name of your machine. The link should take you to a page with a picture of your machine and a link to Download the manual which is a PDF file. Good luck.
7/13/2014 6:27:01 PM • Husqvarna Rose • Answered on Jul 13, 2014
2answers
Need an operation manual for a viking rose
try these sites
sew usa
sewing manuals.com
ebay
7/13/2014 6:22:49 PM • Husqvarna Rose • Answered on Jul 13, 2014
Need manual for rose
7/13/2014 6:21:45 PM • Husqvarna Rose • Answered on Jul 13, 2014
Manual for huskylock 680D
Your local Husqvarna Viking dealer can order one for you.
5/15/2014 7:27:10 PM • Husqvarna Rose • Answered on May 15, 2014
Sewing Machines Logo
186 questions posted
Top Husqvarna Sewing Machines Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Husqvarna Sewing Machines
Most Popular Question
viking rose sewing machine starts stops
  • Sewing Machines
