you should be able to by hooking up the black wire on the dimmer to the hot wire(that comes from the electrical panel) in the wall box and the red wire from dimmer to the switch leg(the wire that goes to light fixture). if the dimmer has a white wire(nuetral wire) you will need to hook that up to the white wires in the wall box....CAUTION!!! when removing the old 1 pole switch, there should only be 2 wires and possibly a green or bare copper ground wire attached to it. if either of the 2 wires(not the ground) are white, IT IS MISLABLED OR MISCOLORED. DO NOT hook the dimmers white wire to it cuz it will fry the dimmer. If this is the case, then most likley you do not have a nuetral in the wall box but look anyway for a couple of white wires tied together with a wire nut and stuffed in the back of the box. if you find those than most likely thats your neutral(check with a wiggy or meter to be sure) and thats where the dimmers white wire goes. hook up the dimmers green wire to a green or bare copper wire in the wall box and then put a wire nut on the dimmers red w/white stripe wire.
Hello. There could be a couple of possibilities. First is the simplest to verify, is it a Companion Dimmer, Standard Dimmer switches or a 600W or 1000W Maestro Wireless Multi-location Dimmer. The Maestro Companion Dimmers can not be used individually, as they do not control a load, and must be used along with a Maestro or Maestro Wireless Multi-location Dimmer. The Campanion Dimmers are also a line/low voltage rating, and rated for incandescent and halogen but may not handle some flourescent fixtures. The other thing I can think of is that you may have interfearence from another item. They are radio frequency (RF) devices that communicate together for wireless control of lights. Here's two links that may be of some help, the second has downloadable install instructions.
You posted under MIR600 single pole digital fade dimmer for incandescent and halogen. Installation manual: http://www.lutron.com/TechnicalDocumentLibrary/030864b.pdf If this is not your dimmer, then add a comment with exact model number so I can read that manual and look for trouble spots.
The manual does not say 'Fan' It appears this dimmer is for incandescent and Halogen lights. Manual gives Lutron 24hr/7day tech support number 1-800-523-9466
If you do not want to add a comment for more free assistance, and do not want to call Lutron, then take advantage of fixya phone service. Expert will walk you through the problem for a price.
Maestro dimmers are not recommended with any CFL for pretty much the reasons you are experiencing. The electronics within the CFLs are probably not letting the power circuitry in the Maestro charge-up - and because of that, it comes as no surprise that adding an incandescent lamp solves the problem. The company makes products that are compatible in their Ariadnia/Toggler & Diva product families, but not Maestro - you just need to make sure the dimmer itself identifies itself as compatible with CFLs.
YOu need to make sure that the maestro you installed is designed for use with electric motors. CHeck out this page on the lutron site... http://www.lutron.com/CMS400/page.aspx?id=16955&mn=1797. THese are the dimmers you can use with a fan. If it is in the same box the magnetic interference can cause the types of reactions you are mentioning.
If this is not the problem you need more info-- is the light part of the fan, is there a separate wire for fan motor and light? what type of switch is controlling the light (assuming the maestro dimmer is controlling the fan motor etc...
