My weed eater is leaking gas, and i dunno where from
Every weekend when i go to use it, the gas has leaking all over the insides and outside, so i clean it up and tried to see where its leaking from but wont leak for me when i do that, please help.
Re: my weed eater is leaking gas, and i dunno where from
Your fuel lines are probably old & brittel they are the first thing to leak on those sometimes they leak around the tank but they are really thin lines & they get hot from engine heat & dry rot easly replace both lines from carb to tank & the leak will be gone most lines are 1/4 lines in most cases
Need to fix your Featherlite Type 1 Gas Trimmer? Use our part lists, interactive diagrams, accessories and expert repair advice to make your repairs easy.
I found the manual for this model weed eater, according to the manual the mixture... and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be mixed at a Ratio of 40:1 ...." and I quote once more from the manual "Helpful Tip. To obtain correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps, If you like I can send the manual via email if you need it.
I believe you have the wrong GAS AND OIL MIXTURE. MOST WEED EATERS are a Ration of 90:1 or even less 75:1 For WEEDEATER I would use a 50:1 or if you choose 32:1 should work. Use a good 2-stroke oil. DO NOT USE ANY OTHER OIL> You see the more oil you use the harder it is to start. Don't forget to Pump the fuel Bulb on the side before trying to start it.About 3 x should do it. GOOD LUCK and it is and does effect me when their is death by a LOVED ONE. My prayers are with you! From Mddoc13 ( BOB)
