Best way to wire the audiobahn eternal
Well, from what I can find, the best you could do is 2 ohm stable. This is only if you have a decent 2 ohm stable amplifier. In order to wire it to 2 ohms you will need to take the positives and hook them together and run one wire to the brigde positive of the amplifier. Then take the negatives and hook them together and run one wire to the bridge negative of the amplifier. Make sure you have a good enough amplifier to run this sub also. I would definately use a mono block amp that is 2 ohm stable and at least 1000 watts. I'm not sure if you have the 10",12", or 15" but 1000 should do it. There is one key that many people miss.......it is just as bad to underpower subs as it is to overpower them. And make sure you get a quality amplifier....if it is a brand new 1000 watt amp and it is under a hundred dollars you are not getting a good amplifier. Amps that I would recommend getting are gently used high end amplifiers, namely Memphis. I'm sorry I've rambled enough, but if you need anymore help just let me know. Good luck
