Motorola Mobility Roadster 2 Universal Bluetooth In-Car Speakerphone Logo
A
Anonymous Posted on Jan 23, 2014
Works for a day or two then quits reseting my info in manual same thing over in 1 or 2 days.
  • Official Brand Answer 1,623 Answers
  • Posted on Feb 03, 2015
Motorola Mobility
Level 0:
Answers
1623
Questions
0
Helped
350760
Points
5677
1helpful
I have a holiday timer LW28080. Following instructions to the letter the unit did not go on at the set time. The manual works but not the timer. Does the time actually have to start on the first day...
LW28080 is NCC brand digital power center.
Copy following link to identify timer and download manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#0050024
Programming should start on the day you selected for Program 1 ON. So if Tues was selected, timer should start Tuesday.
Use paper clip, and push in Reset button for 2 seconds. Repeat. Always reset digital timers before programming to clear memory glitches.
Plug timer in for 10 minutes to charge battery.
Be sure to set current time with correct day, hour am-pm and minute.
Each ON program requires OFF program
Set program 1 ON and then set program 1 OFF.
Make sure selected day(s) of operation match for both ON and OFF settings.
Check am-pm conflicts in programming.
Avoid 12:00, to avoid am-pm confusion. Use 12:01 or 11:59
Avoid programming overlaps and conflicts that cause timer not to function as expected.
When programming is finished, press current time button to return to current time.
It appears timer is ready for programmed operation at this point.
Install Mi-MH battery that comes with timer.
Do not exceed watt rating.
This timer comes with 1 year limited warranty and can be expected to last 1 or 2 seasons, and probably quit season 3.
1-800-730-3707
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
3helpful
I have a Dell Latitude Windows XP laptop that I need to be back to factory settings...how can I do that?
Hey, I also forgot windows xp password several days ago. I tried several free software. It took me two days and got quite messy.
Unfortunately none of them work for me. Finally I made it work with Windows Password Reset . The good news is that it works. The bad news is it is not free. You can try Windows Password Reset Deluxe. It works for me.
Check this out: http://www.windowspasswordreset.net
2helpful
2answers
The passenger front window works sporadically
it is most likely the motor.....when it does this and say that it starts rolling down or up and quits and you wait a minute or so and try again and it starts working again then it is going to need a motor......i hope this will help but if i can help in any other way let me know and give me all the info that you can....let me and fixya know if i was able to help you and a thumbs up and a comment would be appreciated.......thanks and good luck and have a blessed day......
My ST01C works fine for a few days and then resets itself. The clock flashes 12:00am every time it resets and their is no pattern to it resetting. Sometimes it works for 2 days; sometimes 4-5. I reprogram...
My guess, it's the battery... Manual has troubleshooting steps that point to battery.
1) Timer requires CR2 battery to work ... double check markings on your battery. Programs will not function without battery. Battery can be low without BATT warning on screen.
2) ST01C has 1 year limited warranty. Things wear out.
3) When reprogramming, do you Reset timer? Or just reprogram Time-Date. Last-ditch troubleshoot says to Reset and Re-program timer.
2helpful
I need a manual for a noma 5+1+1 thermostat
Hi, i am sorry to say, the operating manual comes with the thermostat. You have a 5 day-2 day programmable Stat. The best thing for you to do, is to take this info. with you to a hardware store, tell them you are having a problem programming it, I am just assuming that is the problem and they can pull a manual that is close and show you how to program it. 5 day is Mon - Fri, and 1-1 is for the 2 day weekend. They all are pretty much the same when programming. Noma is an aftermarket stat. Good Luck, Sincerely,
Shastalaker7
Service reset (oil)
1. Turn ignition switch to position I.
2. Press and hold "day counter reset button".
3. Turn ignition to position II.
4. Continue holding day counter for about 10 seconds.
5. While SRL flashes, release day counter button.
6. Should hear "beep-beep" to confirm command accepted.
Motorola V365 - turns on then off immediatly
I have this phone. There is nothing you can do about this problem. The only thing you can do is hope the phone is still under warranty or you have insurance to replace it. I was surfing on AT&T website and found this information for problem cell phones. I am quite sure you can surf your carrier website and find the same information. Look for something like- how do I replace my broken phone or warranty information. Hope this info helps!!!! Just click on the link below.
For AT&T (Cingular) - the warranty is valid from 31- 365 day from date of purchase.(less than 30 days return to place of purchase) The warranty comes with the phone for free. I missed the warranty window by 10 days ……………What luck.
http://www.wireless.att.com/answer-center/main.jsp?t=solutionTab&ft=&ps=solutionPanels&locale=en_US&_dyncharset=UTF-8&solutionId=KB91429
Cd changer quit
try unpluging the cd and then pluging it back in, thgis shopuld act as a reset.
Mark
Top Motorola Mobility Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Motorola Mobility Car Audio and Video Expert? Answer questions, earn points and help others
