U2 04 EEPROM read/write error (serial communication
error)
11 Counter check sum error (EEPROM)
12 Adjustment value check sum error (EEPROM)
40 CRUM chip communication error
Check EEPROM for proper set-up
To prevent the erasure of counter data
and adjustment values, write down the
counter data and adjustment values by
simulation. (If there is a printer option,
execute SIM23-1 and note counter
data/adjustment values.)
Clear U2 trouble with SIM16.
Replace PCU PWB.
press 0
U2 if 04 occurs EEPROM read/write error (serial communicationerror)
if 11 occurs Counter check sum error (EEPROM)
if 12 occurs Adjustment value check sum error (EEPROM)
if 40 occurs CRUM chip communication error
U2
04
EEPROM serial communication error
11
counter check sum error
12
adjustment value check sum error(EEPROM)
40
CRUM communication error
U2
04
EPROM error
11
Main counter error
12
EPROM error
U2
04
11
12
40
CRUM communication errorYou need the service help. It is no a distans work Good luck)
Content Counter check sum error (EEPROM) Detail Checksum error in counter data area Cause EEPROM defective Control circuit hung up due to noise Defective EEPROM access circuit on PCU PWB Check Check EEPROM for proper set-up and To prevent the erasure of counter data remedy and adjustment values, write down the counter data and adjustment values by simulation. (If there is a printer option, execute SIM23-1 and note counter data/adjustment values.) Clear U2 trouble with SIM16. Replace PCU PWB.
U2 RAM error
U2-00 EPROM error
U2-01 Counter error
U2-01 Memory back-up battery dead
U2-04 EPROM error
U2-11 Main counter error
U2-12 EPROM error
As you can see there are many U2 error codes. Needless to say, find your code and the replace the bad part. The battery is on the main board. The EPROM is on the main board. If you find your code, replace the part and error still remains -- replace main board.
To find out the sub code for the U2 error hold down the Start key. Below is a list of the errors:
U2-04 EEPROM serial communication error
U2-11 Counter check sum error
U2-12 Adjustment value check sum error (EEPROM)
U2-40 CRUM communication error
To clear the U2-40 error try pulling out the toner cartridge and firmly reinstalling it. If that doesn't work you must install a new toner cartridge. There is a CRUM chip on the cartridge that keeps up with how many impressions have been made with that cardridge. You cannot "refill" these cartridges without replacing the CRUM. This problem occurs frequently with remanufactured cartridges.
To clear other U2 errors you must enter simulation mode. Perform the following procedure to enter the simulation mode. Clear key - Interrupt key - "0" key - Interrupt key - 16 - Start key - Start key. The unit should reset.
