Pro-2043
SOURCE: Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
SOURCE: I have pro 135 from radio shack. How do I reset it
The RESET function will clear everything that you have programmed into the scanner and restore original factory settings. You can, however, restore the 150 pre-programmed frequencies after a RESET.
To RESET:
- Power the scanner OFF.
- Hold down the 2, 9, and PSE keys and power the scanner ON.
- CLEAr appears on the display as the scanner resets.
- Do not power the scanner OFF until CLEAr disappears from the display.
To restore the original 150 pre-programmed frequencies:
- Turn the scanner power OFF.
- Hold down the 3 and ENT/PGM keys and power the scanner ON.
Bill B
SOURCE: I have a radio Shack
Hello waltz,
Welcome to FixYa.
My name is John. I will be assisting you with your issue.
1. Press the SRCH button.
2. Select the bank you want to clear all locked-out frequencies.
3. Press the FUNC, L/OUT. Lockout list will appear.
4. Press 6. Confirm list clear? 1=yes, press another key for no.
5. Press 1 to clear all.
I hope this solution was very helpful to your problem.
Thank you for choosing FixYa.
John
