Pride New Mobility Victory XL 4 Wheel Scooter Logo
A
Anonymous Posted on Jan 14, 2014
My pride mobility victory scooter will not charge
Bought new charger, have a power light on the charger, but no indication of charging battery voltage reads only 6 volts
Lawrence Oravetz
Level 3:
  • Pride Master 10,558 Answers
  • Posted on Sep 03, 2017
Lawrence Oravetz
Pride Master
Level 3:
Answers
10558
Questions
Helped
2700486
Points
29284
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
4 Related Answers
Dan Hudson
  • 119 Answers
  • Posted on Nov 27, 2008
SOURCE: Pride victory mobility scooter
A fully charged battery should be over 12 volts. You may need to change your batteries.
Anonymous
  • 63 Answers
  • Posted on Jan 17, 2011
SOURCE: Pride Sundancer. Batteries will not charge. both
batterys may be to low for charger to pick them back up.Sounds like new batterys to me .dobble check that charger just in case by volt testing the neg and positive wires on one battery ,When its hooked up .then do the other to see if power is getting where its suppose to be. Your checking for volt changed .Battery charger checks out good replace batterys that should do it.
Hope I was of some help have a good day.
Anonymous
  • Posted on Mar 17, 2013
SOURCE: my victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jan 10, 2017
SOURCE: I'm working on a pride jet 3 ultra electric wheelchair. New batteries . Doesn't work, doesn't charge. When I plug it in the lights on the console flash. Unplugged there's nothing. Is this the charger
Test the battery charger output voltage.
Want to see why my batteries wont charge. Product is new !
Is the charger getting power? Is the power reaching the battery pack to charge them? If you answer yes to both questions then something has to be wrong with the battery pack.
I can leave it plugged in for 24 hours and not have a full charge. Is this the batteries or the on board charger
There are a few things to consider with this type of problem.
How old are the batteries. When did you last have them tested. Is the charger output ok on load (test with an amp clamp type meter). is the charger the correct one for these batteries, small output chargers take longer to charge big batteries. Are all connection tight on batteries and anything to do with the charging circuit. Plug and socket type connection do fail on poor connections. Check voltage on batteries when on charge and off charge to see if the charger voltage is getting through to the batteries.
1helpful
I have new batteries two weeks old. They now will not charge properly. could it be the charger? This is on a victory 3 scooter
Did someone qualified tell you that you needed new batteries?. I would go back to the battery supplier & go from there.ALSO,if you still have the old ones can they be tested too.Ask them,i hope this helped.Colin
Pride V10 ****** wont hold a charge. It runs out of power afetr 10 minutes,
hi, well how old is the V10 ? please remember a pair of batteries is only as good as the charger...
Regards
Rob
www.gewizrepairs.co.uk
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
3helpful
2answers
Battery charger indicating that batteries are fully charged, but battery meter on the scooter shows no power at all. also the lights, indicaters etc arent working, im presuming that is resulting from the...
With a Pride Scooter the charger will turn green if its fully charged and if there is a bad connection in the wiring with the batteries. If you plug in the charger and the light comes on green right away then there is a problem with the wiring or connections. Take a voltmeter and read the voltage at each battery. Fully charged they should be 13-15 volts each. If they are less than 12 volts then they are not charged and the charger is not working correctly. If the batteries are really low like less than 8 volts each then the scooter might not come on at all. If you find that the batteries have at least 12 volts or more then there is a wiring problem from the rear of the scooter to the front tiller. Pride has a habit of developing problems in the harness running from the rear to the tiller. My suggestion is to contact your provider (where you got the scooter) and have them troubleshoot the scooter. If the scooter is less than a year old then it should be under warranty and your provider will have to fix it under warranty. Sorry I don't have a quick fix for you but scooters are notoriously bad to troubleshoot and repair, especially long distance. Hope this helps you
1helpful
2answers
Scooter is running slow
Have the batteries tested with a load tester. Usually when it starts to move slow it means the batteries are going.
1helpful
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
