Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
Anonymous Posted on May 28, 2009
Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
I want to connect my laptop to LCD tv brand Toshiba REGZA '32' .i just bought 15-pin VGA cable to connect the display and audio cable to connect the audio.My problem is,the is only blue screen appear in LCD tv,
i had press the button FN+F4 to switch the display,but nothing come out to the LCD tv.
  • Anonymous Mar 25, 2014
    connecting to wifi with a pin
Anonymous
Level 1:
  • Contributor 36 Answers
  • Posted on Aug 03, 2009
Anonymous
Contributor
Level 1:
Answers
36
Questions
0
Helped
22819
Points
97
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Connect pc laptop
This TV has a PC interface VGA (HD-15) , so all you need is get a VGA to VGA cable to plug between the VGA output on the PC and TV.
On the PC select the display as external monitor.
On the TV pick the PC input as required input, not the TV tuner.
Here is the manual.
LCD TV 47HL167 Support Toshiba
Laptop lcd screen flickering
compaq is worst......i m also having the same problem with the LCD of my laptop compaq presario CQ40....wat to do????
Dear Sir, We have Toshiba REGZA 24PB1E LCD TV. I want to test our Gigabyte PC GA-G41M-Combo MB with VGA port (15 Pin Connector) Pls let us know how to connect & get the solution ASAP. For...
Hello
With either the PC IN or HDMI connection, you can watch
your computer's display on the TV and hear the sound from the
TV's speakers.
When connecting a PC to the PC IN terminal on the TV, use an
analog RGB (15-pin) computer cable and a PC audio cable.
To use a PC, set the monitor output resolution on the PC
before connecting it to the TV. The following signals can be
displayed:
Format Resolution V. Frequency
VGA 640 × 480 60Hz
SVGA 800 × 600 60Hz
XGA 1024 × 768 60Hz
Other formats or non-standard signals will not be displayed
correctly.
Note:
The PC audio input terminals on the TV are shared with the
HDMI-1 analog audio input terminals
Some PC models cannot be connected to this TV.
OK.
Problem connecting quite new macbook pro to the toshiba regza 57" Z3030 LCD TV... doesn't seem to work
You may find that as Mac uses a different standard for VGA output, the sync will be on a different pin not recognized by the TV.
You may need to purchase a Mac to IBM adapter from a computer store.
Hope this helps.
Compaq 511, 15 pin only , no hdmi, Sharp 40" lcd
Consult the Sharp Manual for VGA specifications and set the Compaq VGA to match accordingly.
I want to sound and vga driver for compaq cq40-133tu for window xp
This link will provide you all the drivers you want for your laptop
http://www.getpcmemory.com/drivers/compaq-presario-cq40-download-compaq-presario-cq40-series-notebook-windows-xp-drivers/
I am unable to connect my IBM Think Pad Laptop to samsung 37lcd
you should be configure the display option , as extended monitor (2nd) output ,
Using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
2helpful
2answers
Which lead do i need
get a pc cable from your local computer shop serial port to serial port and bobs your uncle
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
