50 inch television won't turn back on after a long power outage. Was left plugged in for the over 7 hours power was out. Power bar was turned off when power came back on and everything else started back up when we flicked the switch but not the tv. Any inside tricks to turning this thing back on?
Pull the plug and with the power disconnected hold the power button on for 60 seconds. After at least the 60 seconds plug the tv in and try to start it. If it works great if not , hold the power button in the on position for a count of 20 with the tv plugged in . If theres still no Joy try power with one of your volume buttons at the same time . One of these should provide a hard reset for the tv.
SOLVED 50 panasonic Viera model no TC P50C2 won turn on red light blinks...
SOURCE: tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
SOURCE: panasonic hd tv light blinks 7 times
Unfortunately this appears to be a common issue developing with these Panasonic sets i.e the '7 blinks of death'!
Several customers are complaining about it. The problem is caused by one, both, or all of the following boards: SC board, SD board, and SU board.
Most commonly, the SC board is the one that has failed and because Panasonic have received so many complaints about this issue they are now agreeing to replace the SC board under extended warranty.
However this is not widely known amongst the general public and Panasonic have kept it very quiet.
I would suggest that you make contact with the Panasonic Concierge service centre. Make them aware that you are aware of the SC board issue and that there is an extended warranty on this and ask them to replace it.
However if it happens that one of the other boards has failed be aware that Panasonic are not covering these under warranty and you will be charged for the repair in this case.
The Panasonic Concierge service is available from here
Thanks for using FixYa.
SOURCE: TV turns off by itself & won't turn back on til unplugged, then plugged back in
panasonic 50" th50 turned off and wiil not turn on again.
