I took out the dreg drawer and brew unit to clean it, following the manual's instructions to do so. To reassemble, it simply says "Assemble brew unit and slide in. In doing this do NOT pres position PRESS!"
Ok, I've done that, taken care not to press the PRESS button. But the brew unit doesn't seem to slide in all the way, and the front panel says "brew unit missing". Advice?
Try this, check brew unit on it you will see a small arrow, this has to be pointing at the letter N, whisch is near the handle. Remove the drain tray and dreg tray, check the rails for the brew unit make sure there is no coffee on it, then slide unit in place.
I have the same model and what you have to do is trick the machine that the catching tray is installed and open the door and with a screw driver trick it like the door is closed. This will make the gear turn a few times and you will have to keep going little by little until the gear aligns with the brew unit. My brew unit is back in but no luck with the message going away. I am pretty upset.
