SOURCE: re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. [email protected]
SOURCE: I have a seiko flight watch, unknown of the model, second hand doesn't reset
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
SOURCE: Minute Hand on Stopwatch Will Not Return to Zero
Here is the link where you can download manual for your watch:
http://www.seikousa.com/pdf/SNA_Series.pdf
The last chapter explains how to reset hands to zero.
Do not forget to rate, please.
SOURCE: seiko chronograph alarm
Solution #3 (Posted by Guest on 5 Mar 08) is spot on. Quick and easy method to reset the chrono hands (it was not in my Seiko manual).
Interestingly, this can also be used to set the chrono ahead (or behind--with a little math) for offset timing measurements.
SOURCE: Seiko Chronograph Sport 150 - Problem: After
Please folow this link:
http://www.seiko.co.uk/support/instructionbooklets
Enter your calibre code (its on the back of your watch, it will explain which numbers to you on the website), you'll then be able to download an instruction manual for your watch, this will detail how to adjust hands to their corect starting position :)
Testimonial: "PDF link states reseting the watch is the problem, and now that I have instructions, I should be able to reset the watch. Thanks"
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
Good luck and thanks for using fixya.
