Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
Pull
the button on the side of the watch carefully, the crown, out to its most extended
position. You will need to unlock the crown if your watch has a locking crown. To unlock,
turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
Turn the crown clockwise to move the hands of the watch past the 12
o'clock position on the dial. The day and date will change to indicate
AM setting but will not change for PM setting. It is recommended that
you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
