SOURCE: How can I hook up my ipod without the ipod docking
use your headphone jack, you will need an adapter cable that converts the signal to left / right male RCA jacks. (available at radio shack or on ebay)
these can plug into any red / white inputs EXCEPT phono I use the input labeled CD for my blackberry to listen to MP3's and stream music from Pandora.com
SOURCE: How do I link my Onkyo TX-SR507 to a PC?
It sounds like you don't fully understand the Onkyo's HDMI port assignment procedures.
But why burden an HDMI cable with audio only? Don't you have a coaxial digital or spdif optical output on the PC you could use? That would make things simpler for setup. Just jam it into one of the appropriate audio inputs on the Onkyo.
SOURCE: How can I connect my Onkyo TX-SR507 to a PC to play MP3 files
The easiest way is to use a 1/8" stereo to dual RCA cord and connect the output of the sound card to an AUX input on the receiver. These cables are readily available and cheap. You shoul dhave 3 mini jacks on the back of the computer related to the sound card setup.
1) Audio input mic
2) Audio input line
3) Audio output line
Connect the receiver to the audio output line jack.
Dan
SOURCE: I am looking for the remote control code for a
Pioneer CD player codes for Onkyo universal remotes are: 70032, & 70101.
You can download Onkyo universal remote
codes with
instructions here.
I hope that helps.
SOURCE: onkyo tx-sr507. was listening to music and
standby light flashing means that it has had a thermal meltdown given that the onkyo can not be that old i would contact onkyo support because our model should be under factory warranty
Testimonial: "Thanks for your help. I'll try Onkyo as you suggest. "
"While the Pure Audio listening mode is selected, the video circuitry is turned off and only the HDMI OUT outputs video signals."
