Cable box is hooked up to HDMI 3 and works fine. Today I tried to connect Apple TV and the Pioneer TV doesn't seem to recognize the input --- in any of the HDMI ports except the one connected to the cable box. I've changed inputs, hooked Apple TV to every HDMI input. And nothing happens....
SOURCE: pc connect to plasma tv pioneer pdp hd5070
(1) Have you selected VGA Output on the Laptop?
Usually there is a Function Key combination like Fn Plus F7 to send output to the external VGA Port, usually depicted by a monitor icon on the F7 Key
(2) If still no input to the TV, check the TV manual for the frequency of the VGA Input.
For Windows XP Sometimes you have to go into
Control Panel / Display / Settings /Advanced then Monitor Tab
& look at the Screen Refresh Rate.
Suggest you try lowering that value till it produces a signal.
Good Luck
SOURCE: input 1 for hdmi stopped working. Input 2 works
Reset all setting back to factory setting.Unplug,replug,should work,if ur backlight video it good,not any coponnents damages.
SOURCE: I cannot get the Input
input is shared with component input--one or the other --must choose in set up menu
