2003 Volvo S40 Logo
Anonymous Posted on May 18, 2009
Oil Leaking into the exhaust
I have a 2003 Volvo S40 1.9 Turbo. The car is smoking really bad and at the flex bend in the exhaust you can see where it is soaked inside with oil. I think the seals are bad in the turbo. any suggestions? Thank you!
  • Anonymous Mar 20, 2014
    my 2000 s40 Volvo smokes blue smoke badly and leaks all my oil into the exhaust in a matter of minutes what is wrong with my car?
Anonymous
Level 2:
  • Expert 74 Answers
  • Posted on May 18, 2009
Anonymous
Expert
Level 2:
Answers
74
Questions
0
Helped
36873
Points
249
Hi there, there are chemicals on the market that will soften up the seals but these take time to work i would suggest changing the turbo, you will also have to remove the oil from the exhaust system this can be done with other chemicals like an upper cylinder cleaner feed directly in to the air intake but only after the turbo has be fixed
Regards JR
2answers
My 2002 volvo s40 1.9 T smokes really bad its bluish in color, it seems to smoke more when at a stop. its burning oil...
Blue smoke is often the result of bad rings on the pistons. Engine rebuild time. It is possible that the turbo is leaking oil into your engine.
Oil line diagram
Hi Geoff, The symptoms you describe certainly point to the turbo. The turbo is basically an air compressor. It is operated by spinning a turbine with the hot exhaust gas which is joined to an impeller via a shaft. The shaft runs on a special floating bearing which is lubricated with pressurised engine oil. There are two special oil seals sealing that central shaft section from the impeller and turbine chambers. If either is leaking, oil will leak into the combustion chambers and result in excessive smoke. I do not know if repair kits are available where you reside, they are not available here and special seals are required. You may need to replace the unit with a reconditioned or a new replacement. Regards John
My xc90, 2003 volvo is smoking very badly.
i hope you are using nothing but SYNTHETIC oil.The turbo is intercooled by oil.If the turbo is gone,it will **** oil into the intake system and burn it.
2001 Volvo s40 oil leaking in turbo, smokes white smoke and turbo not kicking in. I have a new head, timing belt waterpump, oxygen sens. valve job, cam pulley all changed. It is still smoking and no turbo....
Water in combustion chamber makes white smoke--suspect that the head gasket is leaking water into the chamber. If oil leaking around turbo, it may have a bad bearing and bad oil seal. Check waste gate valve and control.
Rebuilt turbo installed and car still smokes
what color is the smoke if blue it is oil, if black or grey its fuel ,didyou have theinjectors seviced? if it is oil take it back to who ever rebuilt it
Trowing oil out thru exhaust
think you may have blown your head gasket ( turbo pushing too much boost)
Turbo leaking oil
turbo oil seals will cause a lot of smoking .
2003 saab exhaust smoking bad
It is most likely residue all through the exhaust system, it will burn off, but it may take awhile.
7helpful
5answers
Blue smoke coming from exhaust
blue smoke out of 1.8 turbo its allways bad oil seal inside turbo.need new turbo or rebuild OEM. with 24 years experience working with vw never seen single headhasket go bad on 1.8 turbo engines.blue smoke its 100% turbo every time
Top Volvo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Volvo Expert? Answer questions, earn points and help others
