We had a power surge and the keypad/clock on the upper oven went blank. The lower oven which has a knob control thermostat works fine.
Normally when a power surge lands a direct hit on a non protected circuit board, it will usually fry it completely. you can confirm this by shutting down the power for 5 minutes. if the control doesn't respond after the 5 minutes of no power, this will confirm circuit failure due to the surge and, you will need to replace the board in this case.
Hi
Error
code F0 means that an error with the keypad has occurred. Usually it happens
due to loose ribbon cable on the keypad or the electronic control assembly
itself going bad. To resolve this issue first, disconnect the power to unit and
then gain access to the back of the clock assembly (Electronic Range
Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would
be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable
is not broken and nothing is shorted on the keypad. After this is done insert
the cable back and then plug the unit back to check. If the error is still
there then the electronic control board should be replaced. Hope
this helps...please post back for further assistance.
Daniel
Hi
Error
Daniel
clock display is blank
