Gateway GT5026E, Having daily freezing and crashing issues, Came originally with 1GB ram, now running 4 512MB sticks of ram, and I'm wondering if maybe its the wrong ram or slow and outdated ram casing the issues here
Http://support.gateway.com/s/PC/R/GTModels/5648/5648sp3.shtml
PLACE 1 GB RAM IN THE SLOTS.
UNINSTALL PROGRAMS YOU DON'T USE OR NEED.
SOURCE: Computer keeps rebooting
you either have a bad memory or bad memory slot!
good luck
please mark the post with a fixya
SOURCE: 4gb ram in foxconn n15235
Hello Jobedy
Everything I found pointed to this board being installed in a Packard Bell computer. One listing indicated the board supported up to 2GB of RAM. So, apparently, 4GB won't run on this system.
Your RAM DIMMs are fine. They're reading 1GB ea when inserted because that is the maximum supported per DIMM slot.
So, in the end, the issue is the limitation w/ your motherboard.
SOME HELPFUL INFORMATION:
When you're trying to find info or support on parts installed in an OEM computer (like a Packard Bell), you'll usually have much better luck searching or requesting support using the computer model no. in addition to the (for example) motherboard model no.
The reason is, (w/ respect to motherboards), most are special made by the original manufactuer for the computer manufacturer. They aren't usually going to be "off-the-shelf" motherboards for which documentation and support will be made readily available to the public.
Having the model no. of both the major assembly (computer) **and** the subassembly (motherboard) is the best combination to strike. :)
If you have more questions on this topic, please, let us know. We're happy to help.
If I answered your question, please, take a moment to provide a "FixYa" rating to my solution.
Thank you for using FixYa!
BJ @:)
SOURCE: ADDED NEW RAM NOW MEDION WON'T BOOT UP
You know that there is a limit of amount of ram on your motherboard, try check google for it.
