Akai LCT2715 27 in. LCD Television Logo
A
Anonymous Posted on Dec 22, 2013
Picture is red - Akai LCT2715 27 in. LCD Television
Turn the tv on picture come on all red and fuzzy and then couple seconds later tv turns off and then turns back on with no picture just red screen then turns off and wont turn back on for ten min
It indicates a short at the Red picture tube--set has three picture tubes and each has a socket which processes signal to each tube--each has a single IC chip---in your case either the chip on the red board or the red tube.
If a bright red screen the set will detect something is pulling way too much current and shut the set down for protection---called a shutdown circuit.......
The screen gets red with no picture. so i openned up the back and noticed that the green bulb or picture tube whent iut out after 5 minutes.
yes u have bad picture tube but is not the green is the red , the red picture tube id over voltege , thats way u had red picture ,
1helpful
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
Picture has a red "haze"
the color in my tv is a little faded when theres dark scenes on cant really see picture. Red and Blue really fade into picture
2answers
Canon Rebel pictures in red tint
Take it back to where you bought it and get them to replace it or fix it under the guarantee.
2answers
Hitachi really red picture
Wally, 2 things can cause that, 1) bad solder on red driver transistor (mounted on Red picture tube board) 2) bad red cathode in the red tube which means big bucks (new tube), may not even be available on that old of a set. Hope this helps BMW Rider
Red in picture creates a ghost picture
Sounds like a loose connection in the convergance amp ic's
Picture red
red screen is due to problem in red video circuit. please check 1 supply to red video ckt. 2 crt base loose. 3 components in red video ckt. 4 loose contact in red cathode ckt in crt base. 5 red video transistor. 6 signal coming to red video from signal processor. 7 signal processor ic. as per schematic check web site www.serviceinfo.com good luck.
Red picture
if picture is red & DARK PLEASE componemts of red cathode ckt 1 red video supply 2 ckt & loose contact near red ckt 3 red signal is coming to red video from signal processor 4 crt base loose 5 red signal processor ic. schematic www.serviceinfo.com good luck
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
