Change ringtone when more than 1 phone in a small area
SOURCE: ringtone
While the phone is not in use (do not pick up the receiver), touch the FLASH button, each time you touch it, it will sound a different ring tone. Keep touching the flash button until you get the one you want. When you find the ringtone you want, just lift the receiver from the phone, and then replace it. That should change your setting.
SOURCE: change ringtone
With the handset on the hook press the conf button (the one with three phones on it).
The phone should ring with your current ringtone. Each press of the conf button will advance to the next tone.
pick up the handset and put it down again to select the ringtone.
I think there are 8 to choose from.
SOURCE: How do I save ringtones to my ZTE C78 phone?
Go to the website myxer.com and you can download ringtones. the trick is to download the ringtone twice. it will save to your phone. the only drawback is that you can't hear the ringtone before you download it, but you can always try again. this is a free ringtone site.
SOURCE: How can I change the ringtone on my Toshiba DKT3010SD?
the Above is incorrect... to change ringtone on a toshiba Strata DK series you will need to go to system programming and go to program 80 and choose from 1 of 3.. if its a CTX its in system programming and must be done from admin PC and many more to choose from.
