2002 Mercedes-Benz C-Class Logo
s
schalk Posted on Dec 18, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Steering column wiring
I got a 2002 c 320 merc everything stop working flickers,wipers,hooter speedo cruise dim bright
Cecil Stevens
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 74 Answers
  • Posted on Dec 18, 2013
Cecil Stevens
Expert
Level 2:
New Friend:
Cheetah:
Answers
74
Questions
Helped
18197
Points
141
Maybe u need the parts in the steering column or put in a good working used steering column...
2helpful
The cruise control and the hooter does not work on my steering please help
Does the air bag light come on as well ? The clock spring in the upper steering column is use so your steering wheel button's have power an you can still turn the wheel from right to left . They break no an then ! How to replace clock spring in 2006 Hyundai Sonata
Hi there just bought a nissan np300 2007 model 2.0l petrol motor fist problem the wipers do not work if I put them on the wiper itself gets hot but they do not work . Secondly only the hedlights work on...
Possible multifunction switch or wiper motor problem, The horn is most likely a coiled contact drum under the steering wheel has an open horn circuit, it is called the "Clockspring" contact drum.
How do you remove the steering wheel from a 1974 Super beetle?
hi there,this is all i could find on the internet.
this should show you how to do it.just scroll down on the page and you will see (steering wheel removal.
hope this is for you car.
Steering Column Work
or this one.
Help Just got beetle and need help removing steering wheel beetle
How do I remove left turn signal switch on 2002 silverado
if your bulbs are fine check connections at base of steering column it would be unusual for the switch to be bad this is a multifubction switch it controls not only turns but wipers bright dim controls washers ect if it is bad you'll need to disarm the air bag remove steering wheel remove access panel under steering wheel remove possibly remove pressure plate under the steering wheel if torq bolts aren't visible there will be three unbolt harness at block connector it bolts together remove two flat connectors for block connector rought wires through column then repeat process on reassembly
Front windshiled wipers not working.
blown fuse, faulty wiper motor or faulty wiper switch. Possible you got a bad new wiper motor if you replaced everything in the order you wrote it in.
1helpful
I have a 1991 Mercury Cougar. The wipers on this car do not operate at the correct setting. When its set to off they still go, when set to intermitent they go off etc. Blinkers usually dont work but...
the multi function switch will affect the signals but not the tail lights as they are on their own circuit.with the right side lights only working it sounds like a wiring problem for the left side and the wiring needs to be checked out at the rear of the car.the dim lights on the right side could be not enough voltage supply or a bad ground which again can be related to the wiring problem for the left side.the multi function switch is the switch that you use to turn on the signal lights change low to high beam headlights,turn on the wipers.it is located below the steering wheel with the wires running down the inside of the steering column.the signal switch is also located below the steering wheel on top of the column.the steering wheel will have to be pulled and the plate removed to see the switches and remove them.the wiring connectors are at the base of the steering column under the dash and they are removed by pulling them out through the column upwards and feeding the new ones down through the same way paying attention as to how the wires a routed through the column.
1995 olds royale ls cruise not working
There is a gray colored wire on the back of the pivot pulse dimmer switch assembly that is most likely the culprit. Not the multi function turn signal/wiper/cruise lever, its the wires that go through the column down to the plug just under the dash at the column. You may be able to see these wires using a flashlight looking into the opening behind the turn signal lever pulling the lever like your dimming the lights may help to see this. The wire may be just hanging there. Very common failure due to the fact that these wires move every time you dim your headlamps. You will have to replace the "Pivot pulse dimmer switch assembly". in the steering column. This switch assembly is attached directly to the turn signal switch. Disabling the air bags and removing the steering wheel will be required. If you decide to do this yourself, I would strongly suggest getting a good service manual and following the procedure to the letter.
1helpful
Turn signal handle broke off and is hanging by wires
You can buy the turn signal switch at Napa or other auto parts stores. It's a combination switch. Remove the steering wheel and remove the 2 screws that hold the turn signal switch on, unplug the wires and installation is reverse of removal.
1helpful
2answers
When I pull back to put headlights on bright it doesn't stay. I do not feel the click. Headlights will go bright as long as I hold back on it. Everything else is working fine. I am being told it will cost...
/// new column needs a multi function switch 500 dollars but i would wire around it and add old time floor switch done it lots and it works well get a diagram from the library to find the wires to cut ground switched i believe
The directional light, wipers, brights, are not working
the combination switch may be bad. (wipers, turn signal, hi-lo beam switch)
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
