Forgot password and cant get in and cant remember my hint to the password
Use Hiren's boot CD to remove the windows password.
http://www.hirensbootcd.org/download/ -> Download link inside.
Burn the CD, and follow the video steps:
Enjoy!
SOURCE: HOW TO UPGRADE THE RAM OF Compaq Evo N610C PC Notebook
i cant able to install sound and graphics driver of compaq c 7000
SOURCE: clear power on password
Removing the Time of Year battery will clear the BIOS password. It is located on the underside of the n610c behind the panel covered by the Microsoft COA label. A small phillips screwdriver is required to remove the two screws on the panel. Carefully lift the BR1225 battery with a small flat blade screw driver.
After 10 minutes re-insert the battery. The BIOS Password should now be cleared, as well as other BIOS settings, the time and date.
SOURCE: bios password n610c
Try this: -
Remove your Laptop Li-ion battery module.
Then remove the RTC battery for at least 15min.
Replace RTC, and boot the computer ONLY with the AC-Adapter.
Enter the BIOS and set to boot from USB
SOURCE: How to reset BIOS password for Compaq EVO N160 notebook
Do the following steps -
- Remove the laptop battery
- Remove the CMOS battery
- Leave it for idle for around 15 minutes
- Put the CMOS battery in
- Boot the laptop with AC power
- Then put the laptop battery in.
- The BIOS pwd would have been reset now
- For troubleshotting the battery - Go into BIOS and run the Battery Caliberation tool
Hope this helps.
Thanks,
AK
SOURCE: how to print screen in notebook compaq evo n610c
press the key "Print Screen" "PrnScr" or whatsoever sounds equivalent. If this key is printed outside of the key in color orange, you need to hold down FN key while pressing the "PrnScr" key
