HI, CHECK DALBANI.COM AS THEY HAVE THEM FOR LESS THAN A DOLLAR EACH. THE # SUFFIX TO ONE OF THE THREE CHOICES IS THE ORIGINAL SANYO "PULLS" WHICH MEANS THEY WERE PULLED FROM NEW EQUIPMENT. I HAVE USED THESE PULLS FOR OVER 2 DECADES AND HAVE ALWAYS HAD NO PROBLEMS. I USUALLY USE THESE WHEN THE ORIGINAL NEW ONES ARE 8.00 A PIECE OR SOMETHING LIKE THAT, BUT THEY ALSO HAVE THE ORIGINALS BRAND NEW IN YOU PART NUMBER FOR JUST 1.20 SO I WAS JUST OBTAIN THOSE. OK. HOPE THIS HELPS.....V
The reason you may have some problems locating this part is that the correct number is 2SC5707. You should be able to buy this at Avnet in Manila or sources similar to this. This is a Japanese part using the JIS part numbering system. Please note that the device may also have another letter at the end which may denote the gain and if so, try to buy the same part in case it is gain dependant.
I hope this was of some help to you. 2SC5707 Datasheet PDF Sanyo Semicon Device
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
