Proform CrossTrainer Treadmill Logo
R
Roger Morris Posted on Dec 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Body guard prorunner 5200 motor controller diagram
ernesto cuadra
Level 3:
Top Expert:
  • Proform Master 12,223 Answers
  • Posted on Dec 10, 2013
ernesto cuadra
Proform Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4081502
Points
34431
See the diagram attached and fix it. God bless you
body guard prorunner 5200 motor controller diagram - 83d26120-fbb3-449f-acb9-5bcec9455150.jpg193117b1-28fd-4a03-9766-27c03886d5ee.gif
Prorunner 5200. Where can I get a manual?
Contact Prorunner directly to request it.
1helpful
Prorunner 1600e, owners manual.
Possible similar model Prorunner treadmill, if that is what you are looking for.
https://3gcardiopull1-jlsmjrt.netdna-ssl.com/downloads/3G-Pro-Runner-Manual.pdf
2answers
How to replace transmission belt on x324 john deere lawn tractor
Remove 3 bolts and guard-A
Loose hardware-B-C
Remove nut-D
2answers
How can I replace the guard on my saw
If it is steel u can use J B weld for steel or u can wire weld it if u have the equipment if not take it to a local body shop they will have the equipment to fix it
Jan 30, 2014 • Saws
1helpful
Instruction manual for 42xt prorunner treadmill
Here is the manual for the Prorunner 42XT treadmill. I assume all the other Prorunner versions will be the same.
PDF version has been uploaded to manuals lib - but they take some time to verify it.
https://www.manualslib.com/brand/prorunner/
2answers
I need a schematic for a mc-70 pwm motor controller board
These are a closely guarded secret and not available outside of the factory.
What do you need it for?
1helpful
2answers
Instructions to replace drive belt on toro model14ap80rp744 and daigramn
Hi. Here's the procedure on how to replace the belt. Sad to say i dont have a diagram for that. Please see below instructions.
The mower should be drained of gas and drain the motor oil before starting procedure.
Disconnect spark plug wire from spark plug.
Motor side of the belt:
Remove two bolts under the lawn mower body which holds the top cover over the drive belt.
Remove the belt guard that is around the pulley on the crank shaft.
Then work the belt around the blade and off the the drive pulley.
While blade is removed, sharpen or replace as necessary.
Transmission side of the belt:
Remove the "S" clip on handle for speed / traction cable
Remove the plastic "Rear Baffle" two screws on each side on frame in front of rear wheels one screw in the rear
With the baffle removed, rotate the drive shaft and transmission to gain access
to the pulley drive belt guard, it is held in place with three screws.
Once belt guard is removed, you can easily remove the drive belt
Reverse procedure to replace the belt.
Lubricate drive Axel bearings, wheel bearings, control cables, as necessary.
Replace all fluids as necessary.
Aug 19, 2010 • Toro Garden
How do you change the belt of the m5088520?
Hi There,
Here's step by step instructions for you on how to replace the belt on your Dirt Devil M088520 Featherlite.
Flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips
screwdriver to remove the two screws. Arrows (Diagram 1) show location of screws.
Lift nozzle guard off. Slide belt off motor shaft
(Diagram 2).
Lift and remove brushroll (Diagram 3). Dispose of old belt.
TO REPLACE BELT
1. Place belt on motor shaft, then slip brushroll through belt. Place belt in area of brushroll without bristles (Diagram 4).
2. With belt in place, pull and slide brushroll into nozzle (Diagram 3) making sure that the brushroll end caps are in the correct
orientation (Diagram 3a inset)
IMPORTANT: Rotate brushroll manually to make sure belt is not twisted.
3. Reattach nozzle guard. Secure by locating the 3 tabs in the base slots and replace the screws (Diagram 1).
I really hope that this was helpful to you. If you'd like to download the manual for your vacuum cleaner where I got this information, please see the link below where you may download. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by Fixya users.
Thanks so much.
Dirt Devil M088520 Featherlite Vacuum Cleaner
Owners Manual
Chris Jones
GoVacuum.com
9helpful
Diagram for the tension belt on a Body Guard 955 ErgoCycle
i also need help with this, if anyone can help us solve it it would be much appreciated
Sep 08, 2009 • Cycling
How do i subscribe my nokia 5200 to my packet data to enable me use my operamini
as i write that my problem is so simple hat i fogotten my key guard code and phone lock code so plz help me
Top Proform Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
