Turn the scooter's power switch to the OFF position.
Connect the charger's plug to the charging port on the scooter.
Plug the charger's power cable into a power outlet.
When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
Times recommended for your scooter.
Stop charging when the LED light is completely green.
Disconnect charger from the scooter, then from the power outlet.
Run your scooter before riding it to verify the battery charge.
most chargers I have seen for mobility scooters have a red power light green for charged and orange for charging has your charger always had 2 red lights ........?????
Make sure the free-wheel lever is engaged and the charger is unplugged from the scooter before you try to turn the scooter on. If the battery gauge goes up when you turn the scooter on and there are no beeping sounds you should be good to go.If the battery gauge drops to the red when you try to accelerate slowly, your batteries are shot. (Typical replacement in 24-48 months).If there is any beeping when the key is first turned on then there is a problem and the number of beeps indicates the problem found by the computer during the POST. [Power On Self Test]
