Sony PlayStation 2 (PS2) Console Logo
Mark Sandmeyer Posted on Oct 11, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Parental levels how do i change parental levels on the playstation 2
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 19, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
263
Points
When it asks for your password DO NOT enter a password...hit select button. The screen will read delete password. This is where you enter 7444. It has worked on all 4 of my Playstations, and I got the information from Sony customer service.
Anonymous
Level 1:
  • Posted on Feb 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
263
Points
Put a DVD into the PS2 and let it try to load. When the screen says chenge to level four select yes. When the entry window pops up,press the select button on the controller. It should say reset password or something like that. Put in 7444. Then when you rename the password put in 0000. You will have to do it again 0000.
Once the movie starts, not the menu screen, but the movie actually playing, Press Select button again. The PS2 DVD menu should appear. Cursor over to the toolbox or Setup, and press X. Cursor over to the third icon, and press X. Arrow down to PArental and press X. Change the Parental lockout to OFF.
I am not completely sure about the procedure here but the numbers are correct.
Anonymous
Level 1:
  • Posted on Apr 24, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
263
Points
This password didnt work for mine either.
  • Anonymous Apr 24, 2008
    It really is as simple as.
    1) press select
    (it will say "delete code")
    2) put in 7444
    (then it will ask for a new code)
    3) your done.
A
Anonymous
Umm..this factory password DID NOT work for mine...
Anonymous
Level 3:
  • Master 709 Answers
  • Posted on Oct 12, 2007
Anonymous
Master
Level 3:
Answers
709
Questions
Helped
611880
Points
1733
Put in a DVD, and press select button to go to PS2 DVD menu.  highlight setup menu. Press X.  go to settings I think, and paretal control is there.  Use password 7444.   Usually everyone sets the password to 0000.  Then when you go into the parental settings, turn the level value to OFF
  • Anonymous Oct 13, 2007
    Someone gave me a Does not help vote on this. "basically the information you need to set parent level is here. I may be wrong about exactly which menu puts you on Parent level settings. I do nt keep it in my front line memory and for a free tip, I donot plan on hooking up my PS2 to get the exact route. The factory password 7444 Works every time for PS2 parent level. i am little ticked that someone thought what I posted did not help.
3 Related Answers
Anonymous
  • 709 Answers
  • Posted on Nov 12, 2007
SOURCE: parental codes
Anonymous
  • 161 Answers
  • Posted on Sep 10, 2009
SOURCE: bought a used playstation 2-need to get parental
Here is the procedure to reset the parental lock code:
1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
If this does not work, the other code is usually 0000. However if they change the default password, then it will be hard to find out.
InCaseyWood
Casey Wood
  • 108 Answers
  • Posted on Dec 18, 2009
SOURCE: have a playstation 2 is set on level 8 parental
Just go into your settings and select parental controls. You will have to insert the password and then you should be able to change the setting no problem.
1helpful
Need to know how to turn off parental controls
1. Insert a DVD Movie into the PlayStation®2.
2. You should receive a message informing you that the Parental Level has been set, and asking if youý"d like to allow the disc to play. Highlight "Yes" and then press the X button.
3. A new window will appear asking you to temporarily change the Parental Control to a different level. Again, highlight "Yes", and then press the X button.
4. Another window will appear asking you to enter your Password. Above that window are numbers (0-9).
5. Do not enter your password, but instead, press the select button on your Controller. This will change the text in the window from "Enter Password" to "Delete Password".
6. Using the numbers above the window, input 7444. If successful, you will receive a message stating "Deletion Complete".
7. Press Select. You will now be asked to register a new password. Please select a four-digit code of your choosing.
8. You will be asked to confirm your password selection by inputting the same code once again. If successful, you will receive a message stating "Registration Confirmed".
9. Now you need to turn off the password altogether. The movie should of started playing by now. Press select and chose Setup. Go to the parental control "tab" and set the level to "off".
10. Now you should be able to watch any movie
To change the parental level system
pop in a dvd movie
while playing, press select
got to "setup" then go to the parental control sub menu
find the password screen and enter "7444"
now you should be able to change the pass code to what ever you want.
Parent advisory code, can't play kids movies
Have a playstation 2 is set on level 8 parental and i have been unable to reset parental controls to watch movies
1helpful
I forgot my password for my sons ps2. it is stuck on parental lock. what do i do please!
"quote"
When it asks for a password, press select, then enter 7444 as a password. that will reset the password. Then, enter a new passcode. To can also, using the parental level menu, Change the level to anything you want, or turn it off.
What ever you do, rememeber to eject the disk BEFORE you turn off the console, otherwise the ps2 will not save your changes. "quote"
1helpful
Bought a used playstation 2-need to get parental
2helpful
2answers
Parental lock on cannot open it
Actually its, 'select' then '7444', and all that does is reset the password.
Press the SELECT button and enter the 4-digit number "7444" whenever the Parental Control display asks you for your password. The old password is deleted.
You will then be prompted to enter a new password, enter whatever number you want, something like 0000, or a number that is easy to remember. If you wish to turn it off, just set it to off and forget about passwords.
Notes
- When you play DVDs which do not have the Parental Control function, playback cannot be limited on this player.
- If you do not set a password, you cannot change the settings for playback limitation.
- Depending on the DVD, you may be asked to change the parental control level while playing the disc. In this case, enter your password, the change the level. When you stop playing the DVD, the playback limitation level returns to the original setting.
After changing DVD settings:
To save your changes, be sure to eject the DVD before pressing the RESET button or turning off the unit with the MAIN POWER switch. Please note that changes will not be saved if you reset or turn off the console without first ejecting the DVD.
Sony Playstation 2 manual, pg. 19
Cant play gta 4 online
your routers parental level is probably on 9 mate, you cant play any games like 15 0r 18 online, get your parent to change the parental level.
2answers
Parental control password
i don't know if you changed the parental control code or not but when it comes to put the code press select and then insert 7444 and it will delete the password and will ask you to put the new one then add any three digit number and then when the movie starts press select and go to setup and then parental control tab and turn it off now there will be no passwords..........
16helpful
6answers
Parental codes
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
