20 Most Recent Sony PlayStation® 2 Console Questions & Answers
I need schematic diagram for sony playstation 2
there is a ribbon wire that attatches to the reset button and to the console it is still attached to the reset button where dose it connect to on the console
1/20/2014 10:08:45 PM • Sony... • Answered on Jan 20, 2014
Wont read disc
If you have one of the slim models that has the pop open lid, first thing to try would be cleaning the lens. Usually, I use either isp alcohol or windex and a cotton swab. Just dip the cotton swab in the cleaner and squeeze out the excess liquid. Then GENTLY rub it over the len and give it about 5 min to make sure it dries. If it's one of the original fat ps2s you may want to try one of the commercial lens cleaning discs (though I haven't had much luck with disc based cleaners.) If cleaning the lens doesn't resolve it, it's most likely the optical assembly (that houses the lens) has worn out or possibly even the spinning motor. In either case, it may be cheaper to purchase a used one than repair.
12/26/2013 4:26:49 PM • Sony... • Answered on Dec 26, 2013
Game disk was removed - ERROR
There can be two possible reasons. The first most likely reason, if it is on only 1 game, is that the CD has been damaged too much and cannot read everything on the CD that is has to read on some times.
The second option is that your Playstation is the problem. This is only if it isn't only for one game, but for multiple. This would mean your disk drive is damaged (usually by having an older console).
5/19/2010 11:52:34 AM • Sony... • Answered on May 19, 2010
My PS2 doesn't read all PS game disks.
Some ps1 games don't work right on a ps2.
1/22/2010 11:25:31 PM • Sony... • Answered on Jan 22, 2010
PlayStation 2
whic model do you have? Please clarify.
9/14/2009 5:30:46 AM • Sony... • Answered on Sep 14, 2009
San andreas won't work
did you buy it for a different system check the disk.
8/23/2009 5:12:47 PM • Sony... • Answered on Aug 23, 2009
Need to make ps2 region free
get a modchip installed
5/21/2009 3:35:17 PM • Sony... • Answered on May 21, 2009
PS2 memory card
Have you tried both Memory Card slots? Maybe Final Fantasy Tactices doesn't understand a 16 MB Memory Card since the official Sony ones are only 8 MB's. Maybe you can try one of those?
Let me know if this helps. Please rate.
Greetings,
DarkNeogen.
2/20/2009 1:15:18 AM • Sony... • Answered on Feb 20, 2009
All games in my computer are not working
If the a game will not start on a Playstation 2 its a defect disk.
trying cleaning it.
Remember to not trie and clean the disk in cirkular motions as that can lead to more dust gets in to the disk.
2/4/2009 1:05:13 PM • Sony... • Answered on Feb 04, 2009
2answers
Parental control password
i don't know if you changed the parental control code or not but when it comes to put the code press select and then insert 7444 and it will delete the password and will ask you to put the new one then add any three digit number and then when the movie starts press select and go to setup and then parental control tab and turn it off now there will be no passwords..........
1/19/2009 10:36:24 PM • Sony... • Answered on Jan 19, 2009
Disc read error
take the ps2 apart and clean the laser eye with rubbing alcohol
takes about 10 mins
( i was on my third game before i found this fix) everything works great now! rock on!
11/17/2008 2:58:46 PM • Sony... • Answered on Nov 17, 2008
2answers
Cricket2007
This is the best site i used to visit
www.cheatbook.de
i hope you will find new cheat codes there
10/1/2008 12:55:53 PM • Sony... • Answered on Oct 01, 2008
How to Install PS2 Modchip?
what you need: an IDE harddrive (maxtor or seagate works best. ive got a maxtor diamondback or whatever its called), the online adaptor and hdloader. hdloader can only be found on the internet so google it. if youre interested in my setup then you need the original hdloader then you can go to ps2hd.com and find all the other programs if youre interested in doing cogswap (play burned games without a chip) then also search that site for the ps2 exploit disc and cogswap. each harddrive is different and can require differnt jumper settings. look on your harddrive to figue out what is cs or check te company's website where you put your harddrive on the ide cable matters. when i first installed a secondary harddrive in my computer i had to shift my original harddrive down one position to make room for the secondary and allow it to take the secondary position on the ide cable. if you switch them then your computer will tell you "cannot find primary harddrive" and will not boot. one thing that i didnt mention is that you should also ground yourself after grounding the computer. your body can carry static electricity and if it gets discharged inside of your computer you can destroy components like RAM, the motherboard or even harddrives. to ground yourself touch a part of the metal casing of your computer. this will continue to be updated as i find more things that i forgot to say
7/24/2008 4:28:51 AM • Sony... • Answered on Jul 24, 2008
Longer wires for inside te playstaion?
I'm not sure what wires you mean, but Radio Shack, or similar store, should have anything you need, or at least the means to splice longer wire into the existing line.
If you mean these:
http://www.gshop.com.au/images/ide_133_cable.jpg
Then, yes, they sell all kinds of them. It's called an IDE cable.
Good luck, sounds like an interesting project.
7/12/2008 2:12:49 AM • Sony... • Answered on Jul 12, 2008
Final Fantasy 8 cant load my ps2 memory card while playing on ps2
yes you would need a ps1 memory card to load ps1 game files on ps2
6/10/2008 5:42:04 AM • Sony... • Answered on Jun 10, 2008
2answers
Try using the code 7-4-4-4. It should clear whatever they put in and then you can put your own in.
4/12/2008 1:07:54 AM • Sony... • Answered on Apr 12, 2008
Playstation 2 Loading
have you tryed other games?
If other games work, then your disk is probably damaged try a disk cleaner solution.
3/17/2008 2:45:21 AM • Sony... • Answered on Mar 17, 2008
Guitar Hero III on PS2 Saving Failed
Could be. Maybe the game doesn't recognize the 16 MB. You can try an original 8 MB Sony one. They're not that expensive anymore. But first try the other Memory Card slot.
Let me know if it worked. Please rate.
Greetings,
DarkNeogen.
1/25/2008 3:48:00 PM • Sony... • Answered on Jan 25, 2008
Sony PlayStation® 2 Console Logo
37 questions posted
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
PlayStation Sony
  • PlayStation Sony
Most Popular Question
disc read error
  • Video Game Consoles & Games
