Samsung Bn59-01041a Remote Control Logo
A
Anonymous Posted on Nov 30, 2013
Can not change channels or use numeric pad - Samsung Bn59-01041a Remote Control
How do I operate Sharp LCD TV remote control
First of all
1. **Power On/Off:** Use the "Power" button.
2. **Changing Channels:** Use "Channel Up" and "Channel Down."
3. **Adjusting Volume:** Use "Volume Up" and "Volume Down."
4. **Input Selection:** Use "Input" or "Source" to choose input devices.
5. **Navigating Menus:** Use navigation arrows and "Enter" or "OK."
6. **Mute Function:** Use the "Mute" button.
7. **Number Pad:** Input channel numbers or perform numeric functions.
8. **Special Functions:** Access features like "Menu," "Exit," "Subtitle," or "Info."
9. **Teletext/Closed Captioning:** Access these features if applicable.
10. **Smart TV Features:** Access smart features, apps, or online content if applicable.
11. **Batteries:** Ensure the remote has fresh batteries for responsiveness.
For model-specific details, always refer to your Sharp TV's user manual. If you provide your TV's model number, I can offer more tailored instructions.
How do u enter code on remote
Use the numerical key pad. The same 0~9 buttons as for changing channels.
How to enter maintenance mode KM 3050
Press the STATUS KEY
With the numeric key pad key in 10871087 (if done correctly the display will change and say ENTER MAINTENANCE ITEM)
Enter 201 with the numeric key pad (follow the steps below):
1. Press the start key. 2. Select the [INITIALIZE].
3. Press the start key.
4. Press the center of the + keys. Be sure to press three + keys displayed in order. The touch panel is adjusted automatically.
5. Press the indicated three + keys, and then check the display.
6. Press the stop key. The screen for selecting a maintenance item No. is displayed.
Completion Press the stop key. The screen for selecting a maintenance item No. is displayed.
Now to exit maintenance mode key in 001 with the numeric key pad
Press the Start Key ( you should be back to the status screen, press copy key to go back to the copy mode)
Remember do not go to any other maintenance mode or make any other changes.
It won't change channels using the numerical pad but will when I scroll the up and down key.
replace remote or take it apart and clean it with cotton swabs and rubbing alcohol. If this doesnt help
the problem may be in the dvd itself.
4helpful
Numeric keys not workin g
The key in the top-left of the numeric-pad enables/disables the numeric keypad. Press it once, to make the keypad function as a numeric-pad.
1helpful
Latitude D600, how use FN key to have the numeric pad on
In the system setup (F2 at boot) look for Numlock settings, there should be an option to change the key combination for numlock
Cordless Numeric Pad
If you are using a cordless numeric pad, it likely came with a USB connector. Plug the USB connector in. This should automatically install with Windows plug and play.
You should then be able to punch the numbers in just like you would on a keyboard when you have excel open.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
