Home Security Logo
P
Prasad Posted on Nov 30, 2013
21 inch crt tv
My Samsung ultraslim fit tv is not turning on, when i turn on this then beep sound is coming. Please let me know on this.
Leon Peach
Level 1:
New Friend:
  • Contributor 54 Answers
  • Posted on Dec 09, 2013
Leon Peach
Contributor
Level 1:
New Friend:
Answers
54
Questions
Helped
16626
Points
83
Sound like the bulb has blown. best bet is to just buy a new monitor. it would cost you the same.
Samsung ultraslim crt tv h out supplay blinking
Those blinks are fault indications. To know more visit the site linked here. Blinking codes of many brand sets are given. http://electronicshelponline.blogspot.com/
Hi, I got a samsung ultraslim 21"tv with no picture showing but there is sound. Is there a way I can repair the tube to get the picture back?
Check your power board for any blown capacitors. This is a simple fix if you are handy with a soldering iron. Its a $10 fix likely, if you don't need a new power board. Otherwise check that your sustain boards are not having a similar issue.
1helpful
Onida 21 xcite ultraslim sound problem
faulty capacitors in the audio section
No power Samsung flatscreen CRT 21 inch TV
Check its fuse. Check the rectifier diodes. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
My tv is turning off automaticaly
if your TV has experiencing this for days now, kindly unplug the power cord and press the power button firmly for 2 secs. You turn on the tv and check your tv settings if the sleep mode is still active. Make sure the sleep mode is set to 0.
2answers
When i turn my samsung 50, no pic or sound 3 lcd lights keep flas
Hi friend,,,
welcome to fixya
Commonly for plasma tv's if the screen went out,,the problem will be the CATHODE RAY TUBE,it is costly to buy.if you want you can buy it,,or it may be the D-board problem will be also,,,
but it is unusual,so check the tube.
if your satisfied with my solution PLEASE RATE IT
thank u...
LG `21` INCH TV
If it has been moved or bumped recently the sound you are hearing is the main HT lead that has been displaced. TGhis is a blasck lead with a rubber disk surround at its end that fits into the picture tube. Do not touch without turning TV Off and using rubber gloves to reinsert.
Please rate our help to keep us online
Polaroid ttm-2401
To me, sounds like a picture tube issue. horizontal / vertical controls don't fix it. then its dead.
Top Samsung Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Eric
ADMIN Eric
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
