Oven door is open ---- the lock is in the locked position and will not retract so that the oven door will close all the way.
Unplug the range and take the rear lower panel off. Unplug the wires leading to the lock motor and check for resistance on those two terminals with an ohm meter. If it shows no resistance then the motor will need to be replaced. If it shows resistance then you will need to replace the oven control. Let me know if you have anymore questions. This will solve your problem.
To Unlock the hinge on an Ariston Oven Door
Lay the oven door flat on the worktop with the inner door upwards and the locked hinge facing you.
With a pair of pliers and a good grip on the hinge, force the locked hinge towards you (by pulling it open towards you) and keep it in position by flipping the U piece over.
Fitting the Oven Door
Fit the door to the oven with the metal receivers in the slots on the oven.
Once the receivers are in the slot, fully open the door (in a downward position).
Flip the U shaped pieces over to lock the hinges.
oven door is lock and I can't unloak it
need your help
my stove is not locked but the child safety is on so I can not use the oven how can this be disabled??
Oven door will not open
