Runs but will not carry a heavy load eng boggs down with load and voltage drops
The engine isn't getting enough fuel. Your carburetor needs cleaning. Generators are notorious for gummed carburetors because of the ethanol alcohol in today's gasoline and the generator sitting idle for weeks, months & even years without use wicks moisture into the fuel. Drain your carburetor of gasoline, & remove the carburetor. Clean your carburetor with Carburetor Cleaner spray & make sure the float needle valve & seat are clear of gum & varnish. To help prevent this from happening again, shut off the fuel petcock at the fuel tank and run the generator carburetor out of fuel before you put it away. It'll help keep the carburetor free of gunk. Also, replace the old fuel in the tank with fresh fuel every 3-6 months.
