Kitchen Appliances - Others Logo
Posted on Nov 26, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Icematic n131m Hi. My Ice machine is making Ice, but it is not putting out as fast as it use to. I have cleaned all filters ext.
mike kirschbaum
Level 3:
Genius:
  • Master 1,198 Answers
  • Posted on Nov 27, 2013
mike kirschbaum
Master
Level 3:
Genius:
Answers
1198
Questions
Helped
359658
Points
3184
The more activity the freezer and fridge see, the more cold escapes. If the freezer defrost system gets issues (broken defrost heat coil, stopped up vents, frozen peas in coils) things slow down. Find the defrost timer and mark the knob on it with white-out to see if it moves. It moves very slowly, one rotation a day.
Scotsman ice machine is not making ice goes through the motions but no ice
h=harvest 2=harvest problem 8=makes ice to fast 0=off.most common issue is your senors/ice mach needs to be descaled and clean
We replaced a pc board on a Icematic N131M, but no freezing takes place
check senors and check refrigeration unit
does compressor start
does condenser fan start
is condenser clean
disconnect hot gas valve
i see you are not a fridge tech like me better to get help with it
3answers
Ice machine making cloudy ice
ice maker may need cleaning, filter and/or scale collector changed. IF there is no water fiter you should add one.
I'm having problem with my icematic 132M . I freezes the cubes allright , but the cubes doesnt fall out before the harvest stops, so the cubes is still hanging on in the machine which causes the m
First i would clean the machine per manufacturers instructions with nickel safe cleaner and sanitizer. When the plates get dirty it will cause ice to hang on to plate. Also check the thickness of ice if to thick it will not come off plate.
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Icematic n201. water constantly flowing in over where ice is formed,i take it that shouldnt be happening when ice is being made. any suggestions?
Water is continuously pumped over the evaporator during the freeze cycle.When the machine enters the HARVEST cycle the purge valve opens dumping mineral laden water out the drain.
3answers
My cme 256a8 model scotsman ice melts to fast will not fill my 250 lb. bin in four days. What is the problem? in a hour run time it makes 7 lbs of ice and 4 lbs. water. in one dump cycle it makes 3 lbs...
There are a couple of things to check. The machine must be level. You can remove the front cover and the plastic sheet that covers the plate where the ice is made. Check to see that the water is flowing from the manifold at the top of the plate. You may have to pop the hose off the end of that manifold to clean the water holes out. It must flow evenly over the plate. Probably the most common problem is the radiator coil there the fan draws air through is clogged up so that it can't dissapate heat properly. You should be able to feel a lot of hot air moving through the coils. The fan cycles on and off periodically to maintain a certain pressure in the freon. That is normal. Clean the fan coils and level the machine.
I have an icematic n45s but it's not making ice and it was second hand so dont have the service manual. Does anyone know if there is anything i can do or do i need to get a repair guy out?
i have a icematic F120 and 2 of the 3 led`s are on (the no water led and too hi-loww cond temp 3`stand by) Does anyone know what is the problem.!?
Sep 18, 2009 • Freezers
Top Kitchen Appliances - Others Experts
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
